FS: HONDATA FULL-RACE ITR GSR B16 MOTORS HEADS GT3076R LSD HKS GREDDY TIAL WISECO ARP
Old Aug 5, 2009 | 11:49 AM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Default FS: HONDATA FULL-RACE ITR GSR B16 MOTORS HEADS GT3076R LSD HKS GREDDY TIAL WISECO ARP
Location: Fort Mill sc (Charlotte Area), and Clemson SC
Contact: Jtoedtm@clemson.edu, PM me, or 803 389 3047
Cash, or a possible trade
I AM IN THE MARKET FOR:
• Jeep Cherokee 5 speed 4.0 4x4
• Any diesel truck (manual only)
I have a HUGE stock pile of parts laying around that I would like to get rid of. This time I finally think I’m done. Im in the market for a reliable Jeep Cherokee 4.0 4x4 5 speed- let me know if you have one you would like to sell or possibly trade some parts for-
Prices are for pickup- I have no problem shipping though, and am paypal verified/ an ebay power seller with TONS of vouches.
OBO!
1. Rota Slip Streams spoon copys $500
Great shape, minus one being a slightly different wheel… you cant tell from 5 feet unless you stare
Tires are 205 55 15, and starting to show their age in the front- rears are great
2. Half core civic radiator with slim fan $60
Has B series hoses already attached
Slim fan that worked great on a turbo GSR
3. B series OBD1 GSR Distributor $100
Great shape dizzy fits all b series VTEC motors
OEM Honda
4. P72 Integra GSR Rod $25 (2 available)
Piston has cracked ringlands
No spun bearings
5. 1995 Hydraulic GSR transmission $550
Came from a STOCK low mileage GSR that was wrecked
Purchased from Eric (Agent Smith)- was told it had no grinds, and I trust him
6. 1995 Integra GSR Shift linkage $100
Perfect for EG EK swaps
Comes with shifter as well great shape!
7. 1995 Integra GSR Axles $75
Came from a running car
One axle has 5k on it
8. 1995 Integra GSR B series Mounts $45
Driver size, and passenger side
No rear mount
9. Clutch Master cylinder/ slave cylinder $35
Brand new stuff
10. B series VTEC solenoid $75
From my personal build
11. GSR Camshafts $75
12. GSR Valve cover $60
Stripped, and went through parts wash
13. ARP Head studs $120
For GSR, LSV, B20v etc
BRAND NEW
14. FRESH GSR BLOCK
0 miles on it
EVERY single nut and bolt is included and bagged for easy assembly
Matching main caps, rear main seal carrier, etc included!
All work performed by Lynch in Greenville
Bored .50 over, cleaned, decked, bead blasted, perfect!
When bored, it was bored for 35 wall clearance (BOOST) when used with the wiseco pistons im selling
15. Wiseco 81.5mm pistons $450, 375 with block!
For above block brand new
Rings file fitted for above block
Low compression (9.5ish in GSR block with LS crank)
16. LS Crankshaft $125
Fresh from machine shop
Micropolished, magnafluxed, cleaned, micd, balance checked
Still in bag from Lynch’s machine shop
17. GSR Oil pan $75
Went through parts washer , slight ding doesn’t affect anything
18. GSR Oil Cooler $100
Same as used on ITR
Complete
19. ACL Bearings- for GSR block with LS crank $50
NEW
$50
20. ITR Fuel Rail $50
Flows more fuel
21. 1995 Integra GSR Tranny $750
I will GAURENTEE there are no grinds
BEST I HAVE EVER FELT!
22. Oil Feed line/Return line setup $50
Don’t use junk lines!
Top notch quality!
23. Garrett GT3076R $950
2500 miles
Shaft place, as expected from a ball bearing turbo without coolant or oil in it
Made 420whp on 13 pounds in a BUILT motor and 500 on higher boost!
Includes cooling lines!
Best turbo for a 500 whp car!
24. GM 3 bar map sensor $65
With pig tail
25. LS Transmission HYDRO $950
I purchased this from a guy that had a FULLY built badass integra- it has:
OBX LSD
Fully rebuilt 2500 miles ago
New input shaft bearing
NO GRINDS
$950
26. REV industries Turbo setup $800
SUPER high quality stuff! ( same as full-race, neukin, synapse, RLD etc)
Flanged for T3 non AC 38mm Tial
Includes 3” downpipe, dumptube as well!
Made 420whp with said GT30R
27. Full-Race Motorsports manifold setup $1000
Jet Hot coated manifold
3” downpipe looks rough, but doesn’t leak
Clears EF/DA cross members
28. Tial 38mm WG $175
Great shape!
29. Tial 40mm WG $200
15psi spring
Great shape
30. HKS 50mm WG $300
Unknown spring
BADASS RARE WG!
31. Hytech Manifold $1000
100% Race design
Twin scroll
50mm WG flange
T4 inlet
Originally cost $3000
32. Competition Clutch Stage 5 $150
2500 miles
Showing some wear on the disc
New disc is 100 from CC
Holds well into 600whp range!
33. OBD2a-OBD1 harness $65
Perfect for 96+ integra civic etc
Bought from XENOCRON
New!
34. Tapped LS oil pan $50
-10AN bung
Good shape
35. ARP LS Head studs $75
Good shape 100% complete
36. Chipped P72 $150
Has spoon program I was told
37. Vacuum manifold $30
Good shape
Golden Eagle brand
38. Greddy Cooling plate $60
Fits 94+ integra
Definitely helps- I have read on forums where people logged 10* less coolant temps
RARE
39. 98+ integra ALL RED tail lights
Slight crack (have piece and can be glued back on
$100 plus your stock tails
40. Short ram for integra civic etc $25
41. LS Valvecover $20
OBD0/1 style
Painted red
42. OBD1 LS Distributor $65
Came from running boosted integra
43. LS Head $35
Good shape
Recent valvejob
CHEAP
44. 1995 Integra GSR Oil pump $20
Great shape
For an additional $20 I can shim it to ITR spec for more oil pressure
45. OEM 1995 Integra GSR Throttle body $50
OEM all sensors included
Perfect for your swap!
46. OEM 1995 Integra GSR Intake manifold $100
100% complete
All sensors included
Great shape!
47. 92+ Civic D series shift linkage $25
Fits many more
Cheap as hell
48. OEM GSR Exhaust manifold $35
Few scratches dents etc
From 95 spec integra
49. GSR Hondata Intake manifold gasket $35
Used for low mileage
50. 1999 Civic SI B16A2 PR3 Head $350 FIRM!
Looks to be in pretty good shape
Head, cams, gears only
No vtec solenoid
Tapped for LSVTEC
51. 81.5MM ITR P73 pistons $70
Brand new with rings/wrist pins etc
52. B series/ H series Knock sensor $50
Great shape
Old Aug 5, 2009 | 06:04 PM
nytosc's Avatar
Default Re: FS: HONDATA FULL-RACE ITR GSR B16 MOTORS HEADS GT3076R LSD HKS GREDDY TIAL WISECO
no love?
Old Aug 5, 2009 | 07:29 PM
ivtecnfg2's Avatar
will those p73 itr piston heads fit on gsr rods if so sold!! dont pm me i cant recieve em 89raised@gmail.com is where im at.
Old Aug 5, 2009 | 10:01 PM
V3locity's Avatar
bump for some good stuff. I'm pming you.
Old Aug 6, 2009 | 04:12 AM
nytosc's Avatar
thanks yall
Old Aug 6, 2009 | 02:19 PM
nytosc's Avatar
thanks for the sales guys keep em comin
Old Aug 6, 2009 | 06:19 PM
nytosc's Avatar
up top
Old Aug 7, 2009 | 05:31 AM
nytosc's Avatar
good morning
Old Aug 7, 2009 | 08:03 AM
nytosc's Avatar
turbo sold!!
Old Aug 7, 2009 | 02:31 PM
nytosc's Avatar
Dont be like this guy:
Originally Posted by mr2trd91
hey man can we do $550 shipped on this turbo without any oil or coolant lines to michigan
thanks! paypal ready
Offer me good prices
Old Aug 7, 2009 | 04:57 PM
nytosc's Avatar
up top
Old Aug 8, 2009 | 04:35 AM
nytosc's Avatar
uppppp
Old Aug 8, 2009 | 10:16 AM
nytosc's Avatar
up top
Old Aug 8, 2009 | 05:25 PM
nytosc's Avatar
hot day!
Old Aug 9, 2009 | 04:40 AM
nytosc's Avatar
up top
Old Aug 11, 2009 | 04:08 AM
nytosc's Avatar
bump!
Old Aug 11, 2009 | 07:12 PM
NOSed_b18b's Avatar
is it safe to assume that anything without a picture is already sold??
Old Aug 12, 2009 | 08:36 AM
nytosc's Avatar
Yes sir, I will be updating everything to streamline it- what did you have an interest in?
Old Aug 13, 2009 | 05:27 PM
nytosc's Avatar
up toppp
Old Aug 16, 2009 | 05:02 PM
nytosc's Avatar
up top
Old Aug 17, 2009 | 05:20 AM
nytosc's Avatar
lots of stuff bump!
Old Aug 17, 2009 | 12:17 PM
nytosc's Avatar
upppppppppp
Old Aug 17, 2009 | 06:48 PM
nytosc's Avatar
fastttttttttt
Old Aug 18, 2009 | 05:53 PM
nytosc's Avatar
bump
Old Aug 19, 2009 | 04:49 AM
nytosc's Avatar
uppppp
