Blown bearing, 5lug conversion
ok so i have the stock 97 ex brake set up and my front passengerside bearing is goin badly, and i wanna do a 5 lug conversion but im short on cash atm and found a listing for 32mm ctr 5 lug fronts, if i got those can i run 5 lug in the front and 4 in the back?
Like they said, 5 lug front, 4 lug rear is fine. Just remember you're going to have to use two different sets of wheels. The hub tamer is a pretty good tool for changing bearings and is less than 300 dollars if you decide to swap out your own bearing.
