Burn out
when i do a burn out my car deads down i have a integra type-r i am from grand cayman i changed the fuel filter n it ran great but after like 3 weeks it just started to down down when i burn out i coulkd rev the car to 7 n come off the clutch n it would do a lil burn out n den dead down n get bak up what could get be
If it was the clutch the engine would rev and the wheels would stay stationary (clutch slipping). does your car drive normally otherwise? is it only when you do burnouts or when you're driving hard as well? you may want to check your ignition system if fuel pressure is ok. you could have a bad plug or high tension wire. If not check compression and leak down. Have you checked for fault codes in the ECU?
LOL I just leeched that image of the Pocket Writer's Handbook. That will come in handy.
Have you ever wondered if some of these posts aren't just members trolling to get a response?
Last edited by 98ITR747; Aug 5, 2009 at 05:29 PM. Reason: Added the bit about trolling.
Yeah man. This is getting ridiculous. I have never seen so many shitty *** posts from brand new members in such a short period of time.
yeah, ever since....oooohhhhh i get chills just thinking about it.....that fateful night in november '08 it seems to be getting worse, or maybe we're getting older and smarter?
neinbalance
Nov 29, 2007 12:37 PM
xXx Justin xXx
Jul 6, 2003 12:18 PM
