infamous sticky pedal
Old Aug 5, 2009 | 05:14 AM
rick_rabies's Avatar
I'm not Rick!
Default infamous sticky pedal
every honda i have had, has a sticky pedal when i bought it. but i beat the dog crap out of it and jump on the pedal and it goes away.
but this one is a tuff one. you know when your at a red light and you let off the clutch and push on the gas...and the gas pedal doesnt go its stuck?
and then you stall..uuggh. very annoying. i have to tap the gas to get it up then release the clutch
what have any of you done to fix that problem
Old Aug 5, 2009 | 06:06 AM
MHDesigns's Avatar
Default Re: infamous sticky pedal
I have only had this problem on my current civic. The only reason I had a problem was because my oil pressure line had gotten stuck in the mix. There's not too much with the pedal. Pedal-Cable-TB. Try oiling all the connections/springs in the mix. I oiled mine when I figured out the oil line was snagging. smooth as butter.
If this doesn't work try a new throttle cable, or see if the TB is snagging. Good luck.
Old Aug 5, 2009 | 06:14 AM
I'm not Rick!
ite thanx. ...are you the 9sec red and white hatch guy in AZ?
Old Aug 5, 2009 | 06:21 AM
MHDesigns's Avatar
lol I wish. Black ej8 in AZ. You local?
Old Aug 5, 2009 | 06:23 AM
92ehatch's Avatar
clean the throttle body and see if that helps.
if it doesnt help, replace the throttle cable.
its easy to do, and a new one from majestic honda www.hondaautomotiveparts.com is really cheap.
Old Aug 5, 2009 | 06:45 AM
I'm not Rick!
oh the MHDesigns name sounds fimiliar. it was in the last few months of Honda tuning mag.
Old Aug 5, 2009 | 09:31 AM
sde780's Avatar
i sprayed pb blast at where my throttle cable connects and loosened the cable, fixed it perfectly
Old Aug 5, 2009 | 09:36 AM
fungus mungus's Avatar
I had this problem when I first got my EG hatch w/180K miles on it. I cleaned the throttle body and cable connects and 100K miles later, it still works like a champ.
fm
BNSTKSI
Jul 6, 2011 11:44 AM
Juniorhatch
May 9, 2011 11:51 AM
wes7side5o
15
Mar 16, 2007 06:47 AM
HipHop Junkie
11
Mar 10, 2005 11:23 PM
Calavera
Feb 19, 2002 02:32 PM
