How do I remove rear seats? Help please.
you just have to un-latch the back parts, then work them loose. one at a time
its not that hard once you figure it out.
gl
try to get the middle of each out first.
gl
there are two C style clips on each of the seats (where your back touches). use some pliers or a flat head. after removing those push the seat outwards then it should come off. as far as the bottom seat cushion, if i remember correctly its only a single 10mm bolt on the bottom by the carpet.
Those explanations were not really clear.
Those c-clip thingees are on the lower outside edge of each seat-back.
Pull back the upholstery to see it, and use a pair of pliers to grab the 'tab' and pull out.
Then each seat back can be pushed toward the outside, and unhooked from
the middle anchor.
The bottom seat has a single bolt that is hidden by the passenger-side
back seat. Then it 'unhooks' from holes in the body pan.
Be patient and don't ruin them.
the middle anchor.
Spoon92
Aug 29, 2003 09:51 AM
