Compression Test Results after valve adjustment
Old Aug 24, 2002 | 04:07 PM
Chubz's Avatar
Default Compression Test Results after valve adjustment
Just did a compression test on my engine after a much needed valve adjustment
b16a head with P&P and JUN III cams with a b18c1 block with CTR pistons (12:1 compression). Used a new compression tester, my old one had a leak. This tester doesnt have a 300 psi limit therefore allowing me to go past 300 psi
BEFORE:
Cyl#4=295 PSI
Cyl#3=295 PSI
Cyl#2=290 PSI
Cyl#1=285 PSI
AFTER:
Cyl#4=310 PSI
Cyl#3=310 PSI
Cyl#2=310 PSI
Cyl#1=305 PSI
Pretty good eh?
Old Aug 24, 2002 | 04:15 PM
Cosworth's Avatar
Default Re: Compression Test Results after valve adjustment (GSRalph)
Those numbers kickass!
Old Aug 24, 2002 | 04:42 PM
ZygSpeed's Avatar
Old Aug 24, 2002 | 05:58 PM
Smitdog's Avatar
Default Re: Compression Test Results after valve adjustment (Zygspeed)
Old Aug 24, 2002 | 06:30 PM
Razor's Avatar
Default Re: Compression Test Results after valve adjustment (Smitdog)
damn isn't the stock ITR have 215 PSI? with 10.8:1 compression?
Reid's Avatar
Global Moderator
Default Re: Compression Test Results after valve adjustment (Razor)
Stock USDM ITRs have 10.6:1 compression.
ace8
Dec 1, 2009 04:16 PM
jvtec95
Apr 16, 2007 06:26 PM
luckypon7
Mar 16, 2005 08:52 AM
brent_G
Oct 12, 2003 12:15 AM
NightHawkC5
Feb 24, 2003 04:55 PM
