sudden shut down on freeway
Old Aug 4, 2009 | 04:50 PM
b18bme's Avatar
Default sudden shut down on freeway
98 ls integra just shutdown on me while cruising about 75 on freeway. Pulled over posting from my blackberry! I still get power motor won't even try to crank just wines when I turn the key. What should I check!?
Old Aug 4, 2009 | 05:28 PM
89lsteg's Avatar
Default Re: sudden shut down on freeway
My 89 integra did this to me a few months back, suddenlly shut off while i was driving in the car pool lane on the freeway. It ended up being my Dizzy
Old Aug 4, 2009 | 06:34 PM
HGZ's Avatar
HGZ
if his distributor was bad he should still be able to crank the engine, right?
if i had to guess, i would probably say the alternator is toast..
Old Aug 4, 2009 | 06:59 PM
Bossup!'s Avatar
timing belt went snap
Old Aug 4, 2009 | 07:01 PM
elexkupe's Avatar
check inside the dizzy cap..the rotor could have broken off..... happened to me....cruising on the highway and pop....didn't know until getting it towed home and replacing battery, fuel filter, and ignition module......check all these...the usual suspects... battery posts are loose, fuel pump is turning on when you turn the key, getting a spark...then open up the dist. cap.....good luck
Old Aug 4, 2009 | 08:35 PM
b18bme's Avatar
Ok so got my car home and.......... Timing belt it didnt snap it stripped. So my crank pulley is basically spinning but there is no teeth to grab onto.
Got a new timing belt and putting in tomorrow praying to the integra gods that it wont be bad.
So now what dammage is done??
Old Aug 4, 2009 | 10:48 PM
wunfstgsr's Avatar
Loved
Community Favorite
possible bent valves!
HotDave
Jul 18, 2012 05:02 PM
Scheizty
Jun 7, 2009 05:09 PM
naahnaah
May 4, 2009 10:12 PM
pliskin679
13
Aug 3, 2007 09:30 PM
junya16
Mar 1, 2003 05:41 PM
