EK OEM Tweeter Pod Dimensions
Old Aug 4, 2009 | 10:59 AM
phil_lt1's Avatar
Default EK OEM Tweeter Pod Dimensions
Hey. What are the dimensions of the OEM tweeter pods? I need to know the inside diameter and depth available for tweeters, but I'm on vacation and can't measure mine. I searched quick, but didn't see anything. I have a deal here on components, but I want to make sure the tweets will fit.
If no one responds, I'll measure when I get back and post it (but info now would help alot). Thanks.
Old Aug 5, 2009 | 02:52 PM
phil_lt1's Avatar
Default Re: EK OEM Tweeter Pod Dimensions
Unless someone has different measurements, the pods without modification have a 1-11/16" diameter (43mm) and are 1/2" deep (12mm, rim to bottom).
Please list any known tweeters that fit with little to no modification, with model number if you can.
Old Aug 7, 2009 | 07:16 PM
RyanA's Avatar
Some of the Infinity tweeters and the MB Quart Q series (or newer Reference) tweeters with the 5 bars will fit using just the tweeter and the grille. You have to make a little ring to make the grille sit where you want and the Quart tweeters have a provision for a machine screw through the back to hold them in the pods.
disfreshkidd
Northwest (Sales)
Aug 12, 2011 12:44 PM
94whiteSI
Sep 19, 2007 09:07 PM
92VXeg
Feb 28, 2007 11:34 PM
