timing
Old Aug 4, 2009 | 10:35 AM
89efman's Avatar
New User
Default timing
Hello everyone i have a couple of questions. I have a d16z6 i just finished installing a turbo setup and i had a question about timing how much should i retard the cam or should i retard the crank or just use the distributor. i have a 14b turbo going to be at 8-10 psi i have 310cc rc injectors.
thank you for your help.
Old Aug 4, 2009 | 12:08 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: timing
what the? dont touch it. are you using an fmu or some ecu tuning?
Old Aug 4, 2009 | 12:27 PM
JNocon's Avatar
Default Re: timing
Time to invest in a Service Manual, Turbo that is. It depends on what set up you have and how much boost your doing. If you retard the timing way too much, you'll experience detonation.
Old Aug 6, 2009 | 09:18 AM
89efman's Avatar
New User
Default Re: timing
thanks for the input guys im running a dsm 14b turbo at no more then 10 psi
but right now cause i think my oil pump just went out cause the head seized up the cam shaft i mean and its not getting any oil pressure so the project is on hold if the oil pump went out should i just rebuild the motor or do a motor swap or try to install a new oil pump how hard is it?
Old Aug 6, 2009 | 09:22 AM
I'm not Rick!
Default Re: timing
easy. you just got to jump on the task and dont get overwhelmed. you can do it with the motor in the car. good luck.
Old Aug 6, 2009 | 09:43 AM
92ehatch's Avatar
Default Re: timing
rgr that, not too hard to do with motor in the car
also, once you get it running again, leave the timing at stock 16btdc
chip your p28 and get it tuned properly
or you will have a big headache
Old Aug 6, 2009 | 09:58 AM
D16SiHatch's Avatar
Default Re: timing
i concur ^
Old Aug 6, 2009 | 11:58 AM
92ehatch's Avatar
Default Re: timing
here's what can happen if you dont tune that thing.
Not my car, just a friends from a year go (happend on the way to get it tuned lol)
melty melty
Old Aug 6, 2009 | 01:25 PM
roadsqueegy95's Avatar
Default Re: timing
ouch, thats y ima trailor my car to get tuned instead or risking it by driving!
Ej8_KiD
Oct 2, 2012 10:09 PM
turbo-crx
Jun 9, 2009 10:31 AM
victoriasamantha
May 3, 2006 07:34 PM
