Suspension & Brakes Theory, alignment, spring rates....
gc/konis
Old Aug 4, 2009 | 10:19 AM
chinkyx90's Avatar
Default gc/konis
i got my set of used gc/konis didn't come with anything else but the shock and the coilover sleeve(4).
My question is how do i adjust the height of the coilover? and the comfort of the shock?
Also: do i need to preload the spring? and how do i do it?
Old Aug 4, 2009 | 10:36 AM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: gc/konis
you will adjust the height with the bottom perch. and you will adjust the valving at the top of the shock rod. they should have gave you adjustment *****. let me see if i can find a pic.
Old Aug 4, 2009 | 10:37 AM
Egezzy's Avatar
look at the second one from the left. the white **** on top.
Old Aug 4, 2009 | 10:45 AM
chinkyx90's Avatar
so i will need an hex key to adjust the height? but how will i know that its even
do i adjust it when its on the car?
Old Aug 4, 2009 | 10:49 AM
Egezzy's Avatar
you could count threads or even measure from the perch to the bottom of the threaded section.
Old Aug 4, 2009 | 11:48 AM
chinkyx90's Avatar
Old Aug 4, 2009 | 12:16 PM
Egezzy's Avatar
yes sir.
Old Aug 4, 2009 | 01:00 PM
chinkyx90's Avatar
is there suppose to be a collar on the front shocks? where it meets the fork?
Old Aug 4, 2009 | 01:44 PM
TunerN00b's Avatar
If you're thinking about the brake line bracket, Koni shocks do not include them. You need to either pound off the OEM bracket from the OEM shocks (rubber mallet time), or use zip ties (like so many of us do).
Old Aug 4, 2009 | 01:49 PM
Egezzy's Avatar
your not supposed to give away all the secrets. lol. zipties get it done!
thekza's Avatar
^ As mentioned previously, you can measure or count the rings threads.
Old Aug 4, 2009 | 02:26 PM
chinkyx90's Avatar
do you guys know a good way to take out the long bolt from the forkey thing, it's tightened with a nut
Old Aug 4, 2009 | 04:18 PM
Egezzy's Avatar
to take it off. spray it down with pb blaster then us an impact if you have one to get it off and use a rachet or wrench on the other side.
Old Aug 4, 2009 | 10:24 PM
chinkyx90's Avatar
Okay cool. What type of greaser should i use to prevent them from squeeking?
ribal_gh
Suspension & Brakes
May 9, 2012 08:21 AM
GoLowDrew
Suspension & Brakes
40
Apr 1, 2011 02:14 PM
ieatrice
Dec 27, 2006 07:02 AM
da9pwnsu
Apr 24, 2006 09:17 AM
jdl3000
30
Apr 13, 2004 05:46 AM
