99 Civic Si overheating
Old Aug 4, 2009 | 08:09 AM
Frenchy1337's Avatar
Default 99 Civic Si overheating
Im trying to figure out why the temperature gauge started going up all the sudden. The fan kicks in, there is coolant...could it be the thermostat? The temperature only goes up when I am idling and if I rev the car a little bit I can see the temperature go back down quickly. As soon as I start driving its back to normal until I stop and idle again. I don't really think the car is actually overheating or else I would see smoke since the sometimes it actually goes all the way H in the red but nothing happens. I just rev it or start driving and it goes back down. Any ideas?
Thanks
Old Aug 4, 2009 | 08:26 AM
jdmztrane's Avatar
Default Re: 99 Civic Si overheating
I'm having almost the same problem with my 98 DX. Mine only really does it when the AC is on though. As soon as I start to drive, the temperature falls back to normal. I have no coolant loss and the thermostat was replaced in January.
Bump for some answers for the both of us.
Old Aug 4, 2009 | 09:53 AM
CivicSD's Avatar
possibly a failing water pump
Old Aug 4, 2009 | 09:57 AM
raidacaipo's Avatar
x2!
If it was a thermostat problem, your likely to have hot water shooting straight into your reservoir tank, filling it up. Your fan comes on so I dont think its the thermostat
Old Aug 6, 2009 | 11:08 AM
jdmztrane's Avatar
Originally Posted by raidacaipo
x2!
A buddy of mine (JDM Dan, for what its worth) told me that its a head gasket that is on its way out. My water pump is brand new so I doubt its that.
Old Aug 6, 2009 | 11:39 AM
<j doobestt>'s Avatar
New User
Frenchy1337: Do u have coolant loss or milky substance on oil cap or white exhaust smoke?
JDMztrane: Is your gauge going all the way to H sometimes or no?
Old Aug 6, 2009 | 12:39 PM
jdmztrane's Avatar
If I see it climbing, I try to either pull over in traffic and let it cool down some, or start driving. Yes it has hit H twice while idling.
After I start moving it drops back down to almost normal operating temp.
Old Aug 6, 2009 | 01:36 PM
HondaGuy951's Avatar
My '97 LX is doing the same ****. I'm just replacing it all, Head Gasket, Thermostat, Waterpump, Timing Belt,....ect.
Old Aug 6, 2009 | 01:48 PM
sp00ledbseries's Avatar
radiator or headgasket is my bet if your water pump is new
Old Aug 7, 2009 | 11:56 PM
EKSiR99's Avatar
looks like a blown headgasket
Old Aug 7, 2009 | 11:59 PM
CRXREFIC's Avatar
lol happened on my buddys car it didnt show signs of overheating......
he replace the harness that goes to his clauster and the tempo meter read right....
check if you are reading it right
jpuleo
24
Aug 5, 2015 01:27 PM
hotdoggies
17
Jul 11, 2011 06:18 PM
Lugzilla
16
Jun 15, 2011 11:08 AM
zildjianmatt
May 4, 2010 02:29 AM
lvlistchif
Dec 11, 2009 10:08 AM
