dare you to solve this problem
Old Aug 4, 2009 | 03:16 AM
cadeMFjohnson's Avatar
Default dare you to solve this problem
i run my car, i turn it off and turn it back on, and then my car dies down at very low throttle suddenly, like i can cruise a couple seconds at low throttle, then it acts like i took my foot off the pedal. then it comes back and lurches and i can cruise a few more seconds, repeat.
but if i stop the car and let the rpms drop to an idle then take off again the problem goes away. its driving me insane. tps tested good but im still suspecting it
Old Aug 4, 2009 | 03:39 AM
90Rexx's Avatar
Default Re: dare you to solve this problem
what mods??? engine??
Old Aug 4, 2009 | 05:14 AM
Vindicator9000's Avatar
318 Curves, 11 miles
dirty throttle body. My y8 used to do what I think you're describing. I tried everything, then it went away when I took the TB off and cleaned it really good.
Old Aug 4, 2009 | 06:30 AM
BRP_TX's Avatar
If it isnt the TB then you might want to suspect a fuel pressure issue, most likely a pump. it sounds like its not being able to maintain adequate fuel pressure and its bucking and lurching. just my .02
Old Aug 4, 2009 | 06:37 AM
Former User's Avatar
Is the CEL ON? When was the last tune up? As mentioned, try cleaning the throttle body, adjusting the throttle cable, and lubricating the throttle pedal.
Old Aug 4, 2009 | 06:40 AM
1LowSol's Avatar
Check your injectors, I had a 92 Talon that did the same thing.
Old Aug 4, 2009 | 07:18 AM
angel_i's Avatar
Is it on a B16? Sounds like it could be the IACV acting up.
Old Aug 5, 2009 | 12:57 AM
iacv is what im thinking too, but the zone wants over a hundred bucks for the assy
si0385.
Feb 3, 2006 08:19 PM
Des9255
Oct 24, 2005 09:58 PM
mkinpwrat12g's
Sep 1, 2005 07:12 AM
1QWKGS
Apr 3, 2005 11:52 PM
zccr-xsi
13
Feb 5, 2005 07:59 PM
