"poor mans type r"
Old Aug 24, 2002 | 02:21 PM
neutron91's Avatar
Default "poor mans type r"
does anyone know where i can get some good info on mating a b16a head with a b18c block... thanks
Old Aug 24, 2002 | 02:41 PM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: "poor mans type r" (neutron89)
no info needed. It just bots right up.
Old Aug 24, 2002 | 03:21 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: "poor mans type r" (mannyman)
Old Aug 24, 2002 | 05:39 PM
Deluzional's Avatar
Thats not a poor mans itr, why you gonna bolt a vtec head to a vtec block, Its suppose to be a vtec head bolted onto a non-vtec block
Old Aug 24, 2002 | 05:42 PM
StinkyTofu's Avatar
Default Re: "poor mans type r" (Deluzional)
Don't do it, you're gonna lose power. I don't think the b16a head flows any better than the GSR head, plus you will lose compression.
Old Aug 24, 2002 | 06:19 PM
IC x Prince's Avatar
New User
Default Re: "poor mans type r" (StinkyTofu)
it doesn't have to be a non vtec block, b18c1 is still a good choice.
Your right, the gsr head flows better than the b16, although if it doesn't have a head already, you might be able to find a b16 header alot easier the a GSR.
Old Aug 24, 2002 | 06:48 PM
95gsr's Avatar
Default Re: "poor mans type r" (UltraGSR)
notonly the flow you loss compression if you use b16 head correct me if i'm wrong but thats what i am told.
Old Aug 24, 2002 | 06:52 PM
New User
Default Re: "poor mans type r" (95gsr)
That is true too.
Old Aug 24, 2002 | 07:53 PM
neo1z's Avatar
so basically dont do it.
Old Aug 24, 2002 | 11:42 PM
TurbothisLS's Avatar
Default Re: "poor mans type r" (neo1z)
why would you lose compression?
I heard the b16 head runs higher compression than a gsr...
Old Aug 24, 2002 | 11:45 PM
SIK IN DA HED's Avatar
New User
Default Re: "poor mans type r" (TurbothisLS)
blah! just keep the gsr head on.
Old Aug 25, 2002 | 02:06 AM
ILOVEGIRLS's Avatar
its the way the combustion chamber was designed.
Old Aug 25, 2002 | 03:15 AM
vteg's Avatar
New User
The b16 head has higher combustion chamber volume(cc's) than the gsr head. You will need pistons to get the compression back.
As far as performance, the b16 supposedly has a slight advantage over the stock gsr head. If you are going to have head work done the gsr head is supposed to be better. The ports are higher in the head giving a straighter shot at the valves.
Old Aug 25, 2002 | 07:48 AM
New User
I dont remember him saying he had the GSR head on the block. my friend warped the head on his GSR so he did the b61 head thing. he used endyne pistons and all the other crap so now it a 12's vehicle.
Old Aug 25, 2002 | 07:49 AM
New User
Default Re: "poor mans type r" (dlplayboy)
does he have the head on the car? It wasn't sure he did?
Old Aug 25, 2002 | 09:08 AM
New User
Default Re: "poor mans type r" (ridge racer 2)
can you say waste of $$$
no why whould it be a waste of money?
Old Aug 25, 2002 | 09:11 AM
New User
where did he say he is takeing the GSR head off? what if he doens't have the head...if a b16 head is a waste of $$$, what should he get, an LS head?
Old Aug 25, 2002 | 09:40 AM
Malice's Avatar
New User
that statement is a crock of ****...
true, you do lose like .1-.2 compression my putting on a B16 head on a GSR block. a thinner head gasket or B16 pistons will take care of that. no biggie. the B16 is better if u get higher lift cams. especially if u port and polish it. im going for this setup now. all i need is my skunk valvetraina dn then my b16 head is getting shipped to portflow. i should be over 200whp easy with this setup
Old Aug 25, 2002 | 10:00 AM
1 2 NV's Avatar
Default Re: "poor mans type r" (MaliceGSR)
with a B16 head u lose .4 compression points. y is everyone claiming .1 and .2 points, its .4. do the math it works.
Old Aug 25, 2002 | 10:46 AM
New User
Default Re: "poor mans type r" (hondaatwsu)
all this math stuff...how easy is it to get a GSR head over a b16 head. that's where it all boils down too.
Old Aug 25, 2002 | 10:49 AM
1 2 NV's Avatar
i hear that, im lookin for a GSR head but i want a newer one 99+ only. dont want something thats been thrashed on or worn out. plus smaller combustion chamber, woohoo.
Old Nov 6, 2002 | 02:34 PM
White Lightnin's Avatar
What about taking a b16 head getting it a p&p and new valvetrain and cams. Would the loss of compression mate well to forced induction?
Old Nov 6, 2002 | 03:29 PM
butthole's Avatar
Default Re: "poor mans type r" (White Lightnin)
dose the b18c head bolt right up to the b18a/b
Old Nov 6, 2002 | 03:43 PM
Malice's Avatar
New User
Default Re: "poor mans type r" (butthole)
yes, its called LS/VTEC
heres another thread on this same subject
https://honda-tech.com/zerothread?id=326648
Old Nov 6, 2002 | 04:44 PM
Fuuma0083's Avatar
How is this a Poor Mans Type R???
