Need your input about a weird problem
Old Aug 3, 2009 | 11:32 PM
vndsd1's Avatar
Default Need your input about a weird problem
I start my car up and it starts to shake, the engine sound really weak like it barely running and a few seconds later the engine turns off competely. I then turn the key in the ignition and the engine would runs a little stronger but still sound like it about to die out, but if i give it a little gas (still in neutral) then the engine wont turn off. If i immediately put it into gear and start driving then its fine. But if i turn on the car and chill for a bit then the engine would just turn off. You guys might know whats wrong?
Old Aug 4, 2009 | 12:20 AM
masuya_04's Avatar
Default Re: Need your input about a weird problem
sounds to me you have a problem relating fuel. my guess is your fuel pump isn't pumping enough fuel. correct if i'm wrong...but that's what i think.
Old Aug 4, 2009 | 12:23 AM
vndsd1's Avatar
thanks for the reply, your info is very helpful. so is there any way i can check it that the feul pump is the problem
Old Aug 4, 2009 | 12:30 AM
masuya_04's Avatar
they can start have running problem issues but most of the time they just feel like your running out of gas then die. if its running you can do a fuel pressure test to see if it is getting weak, and there are no sensors for the fuel pump to activate the "check engine light". check the basics first:・ 1) engine oil level. ・ 2) coolant level. ・ 3) pulleys, and belts.
Old Aug 4, 2009 | 07:48 AM
Kidd's Avatar
check your injector clips and make sure they are clamp down good and secure
dayaftertomorrow33
Feb 11, 2009 08:24 PM
P_t0wn
Jan 7, 2006 09:42 PM
dave24
Nov 11, 2005 11:37 PM
charjacq
18
Jul 2, 2002 07:19 PM
