vtec problem
just finish installing h22 swap in my 96 accord- my problem is if vtec pressure sensor is hooked on- it bogs down and dies. it will not start until you disconnect vtec pressure sensor-i installed new sensor but still happens- no codes when car dies and vtec pressure sensor code if disconnected- any ideas- is my ecu the problem- got ground and voltage at the pin, thanks peeps
