Suspension & Brakes Theory, alignment, spring rates....
ohlins dc2 itr coilovers how can i adjust ride height?
Old Aug 3, 2009 | 03:13 PM
CapnKrunch's Avatar
Default ohlins dc2 itr coilovers how can i adjust ride height?
i recently aquired an ej1 with dc2 itr ohlins coilovers on it. I would love to know how to adjust these, they seem pretty complicated though, i see a slit at the top of the shock and there is room for an allen key and then on the shock there are grooves in the shock body but they are not threaded to lower the spring perch which confuses me. how do i adjust the dampening and ride height on these coilovers?
Old Aug 3, 2009 | 03:41 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: ohlins dc2 itr coilovers how can i adjust ride height?
is there a bolt on the perch?? do you have pics?
Old Aug 3, 2009 | 06:42 PM
CapnKrunch's Avatar
i figured out how to adjust the dampening just loosten or tighten the top of the strut with the allen key and it clicks. but there is no bolt on the perch it just wraps around the strut and then dips down in one area for the spring.. and i dont have a camera at this time... ill try and get some up though.
Old Aug 3, 2009 | 10:37 PM
CapnKrunch's Avatar
bump for help. could i replace the springs?
Old Aug 3, 2009 | 11:08 PM
da9leo's Avatar
I <3 DA's
Originally Posted by CapnKrunch
bump for help.
we would help if you posted pics
Old Aug 4, 2009 | 08:19 AM
blaze the chemi's Avatar
http://www.lmgtfy.com/?q=Ohlins+suspension
Try the second or third link that returned.
Give Ohlin's a call. I'm sure their technical department could help you.
Old Aug 6, 2009 | 07:21 AM
Stinkycheezmonky's Avatar
Suspetise...
There is a thin coiled spring (we'll call it the height-spring to avoid confusion)that sits in those grooves, and then the spring perch is held up by that height-spring. To change the height, you have to remove tension from the spring perch (by either compressing the main spring or removing it), and then roll the height-spring up or down on the shock to the desired groove. The last step is of course to let the spring perch rest back on that little guy and reassemble/decompress.
There's a chance you have a metal c-clip instead of the height-spring, but the principle is the same. It's an old Ohlins design, and unfortunately kind of sucks. Mine are the same way. I was considering a threaded sleeve to remedy that, but then wound up magically having a 49.6% crossweight, and so decided that was close enough
boraVr
Suspension & Brakes
Oct 25, 2007 11:26 AM
2doorsMOthanU
Suspension & Brakes
May 4, 2007 08:24 AM
pizzle
Suspension & Brakes
18
Mar 22, 2007 08:48 AM
allanonjj
Suspension & Brakes
13
Aug 19, 2005 12:27 PM
