HELP!!! SERIOUS NOOB QUESTION
Ok so i'm planning on doing a swap in my 89 crx first time never done one before the engine i'm getting from my friend is a d16a vtec out of his coupe what all do i need to do this swap? i hear from many it is a pretty simple swap but if someone can help me thankz
you sure you put the right engine code...i dont see any d16a vtec engine info at all...are you sure your actually refering to a d16z6 engine
You will need the timing belt side motor mount (some slight belt cover cutting)
ECU
OBD-1 conversion
Not sure what trim your CRX is, but you might need to do an MPFI conversion too.
ECU
OBD-1 conversion
Ragonak
Jun 11, 2008 05:35 AM
