ECU harness pins
can i use obd2 pins from a 2000 civic on my obd1 civic harness, reason why i ask is because my civic which is a 92 doesn not have a knock sensor wire/pin and i have a 2000 civic ecu harness and thought i can use the pins for the knock sensor instead of stuffing a straight wire into the connector
Look at the pin design/size. If they look the same then drop one in.
If that doesn't work check out the free stuff forum. There was another thread of somebody needing a couple pins.
4door93civic
Apr 11, 2007 10:16 PM
