just swapped new motor, having some issues
Old Aug 3, 2009 | 08:12 AM
OBDII Integra's Avatar
Default just swapped new motor, having some issues
Whats up guys.... recently i just put in a gsr motor in my car, and since then Its just been problems. I noticed today that when Im driving at about 75 and it goes to 4000rpms in 5th gear it cuts off, the car sttays on but when i hit the gas nothing happens, but when i slow down and go to a lwoer gear it kicks back in.
Another issue is when I press down on the clutch i hear this whining noise but when i let off its fine, when its been drivin for awhile it happpens all the time.
Any ideas??
Old Aug 3, 2009 | 08:29 AM
ek-g6's Avatar
Default Re: just swapped new motor, having some issues
i think throwout bearing for the whining noise, and your ignition coil could have went bad.
Old Aug 3, 2009 | 08:31 AM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
^x2 on the throw out bearing.
Old Aug 3, 2009 | 09:49 AM
Yea i was moving towards the throwout bearing as well......but as far as the car shutting off,what wold be the reasoning it would only cut off while im cruising at a higher speed in 5th gear but if im crusing at like 50 in 5th gear its fine
Old Aug 3, 2009 | 09:52 AM
ek-g6's Avatar
i still think the ignition coil is the problem. A bad one will do that to you at certain rpms. I would take it to get it checked.
Rooftop voter
Transmission & Drivetrain
Nov 1, 2010 06:54 PM
itsLOUiSduh
Mar 9, 2009 08:35 PM
vdawg559
12
Jun 9, 2008 06:21 AM
Stein
Feb 11, 2005 04:49 PM
