gsr overheating
Old Aug 2, 2009 | 08:59 PM
NHB GSR's Avatar
Default gsr overheating
need some help figuring out wats wrong with my teg cause its overheating. dunno if its either the radiator or water pump. u can smell radiator fluid from inside the car when its running. and when its at a stop it starts overheating, when u drive it drops back down a little. but even when it drops down the temp is still really high like very close to the half mark. any help would be apreciated...
Old Aug 2, 2009 | 09:22 PM
ek-g6's Avatar
Default Re: gsr overheating
Could be the thermostat, when was the last time it was changed. Do you see any visible leaks? Is your fan kicking on?
Old Aug 3, 2009 | 01:07 AM
NHB GSR's Avatar
yes there are leaks but its never been overheating b4. the leak is from the hose that connect from the throttle body to the plug under the distributor. also seems to run outa coolant extremly fast now to. dunno if its all from the leak.
Old Aug 3, 2009 | 01:54 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
You have answered your own thread. Fix all leaks, bleed the system of air. Replace the thermostat. And make sure the fans come on and your problems should go away. If not I would look into the head gasket being bad and test for it.
Old Aug 3, 2009 | 12:04 PM
ILS_09's Avatar
x2 right on
ADIZZLE08
Honda Civic (2001 - 2005)
13
May 11, 2010 08:15 PM
EM88
Jul 21, 2009 03:12 AM
new_climber
Dec 14, 2008 10:07 PM
mR. Vash
Aug 20, 2004 04:46 PM
Gabe_
12
Jun 13, 2003 02:47 AM
