No power except to Hazards after Headgasket change!?
Old Aug 2, 2009 | 08:56 PM
aleks77's Avatar
Default No power except to Hazards after Headgasket change!?
Car is a 91 accord 5spd
hey guys i just changed the headgasket and i put everything back together but i have no power anywhere, only thing that works are the Hazards, here is things i did:
Battery disconnected for 1 month
ECU fuse pulled and left out for 1 month
Painted Intake Manifold
Sprayed HG with copper spray (not sure maybe the block is grounded but the head is not now?)
I tried booster cables with another car, same thing
- No power at the alternator (not sure if there is supposed to be constant?)
- Power at the starter
- Thought maybe the T-stat is not grounded now? So i connected booster cables to the T-stat AND intake manifold, and ground them both to a good ground source, still nothing
Any help is appreciated!!
Old Aug 3, 2009 | 01:31 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: No power except to Hazards after Headgasket change!?
Do you have a dvm? If so I can walk you threw a few things to check.
Old Aug 3, 2009 | 12:21 PM
aleks77's Avatar
hey figured it out it was the 80 AMP Battery fuse (main fuse?) replaced it everything works
BrandonPell
Aug 30, 2018 11:03 AM
GPC91
May 23, 2013 09:15 AM
nostreble
Jan 5, 2007 06:41 PM
keepitngga1
Nov 28, 2006 01:49 PM
ekoms31
15
Jun 21, 2005 10:42 AM
