94-97 H22 auto tranny to 1999 F23 engine (199acura CL)??
Old Aug 2, 2009 | 07:24 PM
hondaStarter's Avatar
Default 94-97 H22 auto tranny to 1999 F23 engine (199acura CL)??
the tranny on my 1999 acura CL is gone. I found an H22 auto tranny from 94-97 prelude. IM about to buy it and put it in my 1999 CL.
1. Will it bolt up?
2. Will there be a problem with the TCU?
I read in the threads here in HT that F22 trannys may not fit to F23 because they have different TCU. They said that TCU in F23 is built-in in the ECU while TCU in F22 is separate from the ECU.
Is it also the case in H22 tranny?
PLs help me with this. I dont want to get into trouble of replacing the ECU.. Thanks in advance
Old Aug 3, 2009 | 01:40 AM
YeuEmMaiMai's Avatar
Default Re: 94-97 H22 auto tranny to 1999 F23 engine (199acura CL)??
yes it will bolt up and no it will not run since they are 2 different designs. The TCU and ECM are combined into one for that car
V6 or I4?
Old Aug 3, 2009 | 04:19 AM
yup.. of course its a I4.. its a F23.. thanks for the info..anyone else
Old Aug 3, 2009 | 05:30 PM
is there a remedy I can do to fit the H22 auto tranny to f23?? pls help
Old Aug 3, 2009 | 05:40 PM
nus_dogg's Avatar
F and H are all interchange-able; same goes with clutch & flywheel. So no mods needed.
Old Aug 3, 2009 | 09:13 PM
NOT GOING TO WORK, it will bolt up but ECM and TCU are one unit on the CL versus 2 on the Prelude and the electrical connectors are different as well
Ransom
Feb 16, 2017 04:08 AM
Auto96accord
Nov 23, 2006 12:39 AM
97civicsedan
Oct 15, 2005 09:07 AM
Superdragr45
May 3, 2003 04:46 PM
Accord EX-R (Canadian)
Jun 3, 2002 12:12 PM
