How do you remove rear plate garnish on the del sol????
I have all the nuts out.. and theres the 2 tabs.. and i dont want to flex this bad.. can i punch those out with a punch or whats the simple trick on gettting these out???/
Thanks
Thanks
its just the rear plate frame to come off??? shouldnt need a pic its simple understanding.. what you bolt your plate too.. how do you get that whole piece off after removing all the nuts
when i cut them off (inside of trunk), I cut around them nut (not through screw, you notice a difference if using a dremel), then used pliers to twist it off, If you do it right away when still super hot from cutting tool, real easily to spin off,
but if you got a badass cutting tool cut the whole damn thing off (nut and bolt)
no problem it was funny, cause i had thte hardest time removing that plate today to change my rear bumper, and every now and then( once a year), i check this site and what do you know
FredrikL
Jul 11, 2009 06:00 AM
_Spugen_
Jan 5, 2005 08:47 AM
dseriessol
Mar 14, 2003 02:42 PM
