just swapped motor...dash lights dont work..
Old Aug 2, 2009 | 05:46 PM
jxhxb's Avatar
Default just swapped motor...dash lights dont work..
i just put a d series motor back into my 92 eg dx hatchback.... and the headlights and turn signals work and hazards and everything work but the gauge cluster lights, climate control lights and dash lights dont work...
any clues???
i dont understand which fuses to check for this or what else it could be???
thanks for any help! its basically the last thing im getting down to
also i have a broken speed sensor in right now i dont know if that would have to do with any of it though??
Old Aug 2, 2009 | 05:53 PM
lhd dc2's Avatar
Default Re: just swapped motor...dash lights dont work..
Did you mess with the cabin harness behind the dash? I would remove the cluster and check the ground and the harness for the cluster/climate control to see if its actually still attached to the cabin harness. Something might have came loose annd also double check the fuse.
raidacaipo's Avatar
go underneath your steering wheel, take a flash light and check all your fuses!! this will take time but its worth it if you have a single problem. Also are you reusing the original engine harness off your car?
Old Aug 2, 2009 | 10:17 PM
jxhxb's Avatar
yes im using the stock harness... and i didnt mess with the cabin harness...ill check tomorrow but i dont even know where the ground is behind the cluster but ill take a look
any other ideas???
thanks for the help ill keep everyone posted
Old Aug 3, 2009 | 12:26 PM
lhd dc2's Avatar
any other ideas???
The ground from the cluster harness is connected to the metal bar behind the cluster.
sam0218
Mar 13, 2011 07:45 PM
92bseries
May 31, 2009 08:50 AM
eg6-crvtec65
10
Mar 27, 2007 04:06 PM
Coolest Dude Ever
Sep 1, 2006 10:26 AM
HondaHemi
May 12, 2005 09:05 PM
