Cruise Control Removal
Old Aug 2, 2009 | 04:28 PM
TheCivicMafia's Avatar
Default Cruise Control Removal
When i go to remove this, is there anything i need to do beside take out the cruise control system. Like capping vac lines or anything?
Old Aug 2, 2009 | 05:39 PM
luke_1's Avatar
Default Re: Cruise Control Removal
disconnect cable to tb, disconnect electrical connectors, disconnect & block-off vac lines, and remove the actuator.
I removed my on my 4th gen and had no problems
Old Aug 2, 2009 | 08:05 PM
92slowcivic's Avatar
out of curiosity, why would you remove cruise control?
(i'm not being a smart ***, i just want to know why you would, unless it will no longer be a street car.)
Old Aug 2, 2009 | 08:06 PM
crazes's Avatar
Moderator
yea it sucks to remove... i miss it already...going to the drag race i would turn on cruise control and drive at 65mph with out having to have my foot on the gas pedal ..
Old Aug 4, 2009 | 03:42 AM
Mervin's Avatar
You will need to cap a vacuum.
The cruise control itself is held bij 2 x 10mm bolts.
There are two thick breather lines from the cruise control module:
1 - routed vertically down: breather
2 - routed to the fender: connects to a vacuum tank
These can all be pulled out and no need to cap anything.
The cable is connected to the gas pedal.
There is a mechanism on the gas pedal that keeps the pedal depressed once CC is engaged.
Take the CC cable off this mechanism: it should be right beside the throttle cable.
Loosen 10mm bolt to lift fusebox under hood.
There should be a grommet for the CC cable: 1/4 turn to take it off.
Remove cable assemble fusebox and youre done
GL!
Old Aug 4, 2009 | 11:48 PM
HondaVerno's Avatar
how do you take off the cable thats connected to the pedal? damn that thing is hella hard!!!
Old Aug 5, 2009 | 02:14 AM
Mervin's Avatar
its not hard at all, its just that your position under the steering wheel will be awkward and theres no light to see what youre doing.
The principle is the same as the throttle cable @ the throttle body..............depress gas pedal fully and guide cable off the reel vor like a half turn.
I forgot if it was upwards or downwards though.....Flashlight FTW!
Old Aug 5, 2009 | 07:35 AM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
Aftermarket steering wheel that you don't want to mount buttons on, engine bay tuck, never use it, doesn't work.
Actually, all of the above were true for me.
Old Aug 5, 2009 | 10:25 AM
My prelude isnt a Distance car, its getting boosted at above average psi. This is my Around town car, And theres no need for cruise control. Always stopping, or slowing defeats the purpose of CC.
Thanks, That actually help alot mervin
But isnt there a electrical cruise control unit under the Dash ( Driver side )
Old Aug 5, 2009 | 10:28 AM
5SpdH22's Avatar
something gnarly
Mervin's directions sound like they are for RHD in case you didn't notice. (or maybe 5th gen?)
There might be something under the dash, but you won't need to remove it. Unless you're that concerned about weight.
And you do need to cap the lines going to the IM.
Old Aug 5, 2009 | 10:29 AM
I'd Prefer to remove everything, That being the point of spending the time doing it, Ludes already weigh a ton, no need to keep anything unnecessary.
Old Aug 5, 2009 | 10:38 AM
5SpdH22's Avatar
something gnarly
Ok, I'd have to look in my manual when I get home, but there might not even be anything else to it. Maybe a relay or something tiny that will make no difference.
Old Aug 5, 2009 | 10:39 AM
Yeah relays, fuses are no big deal lol. The Cruise Control unit im speaking of is about half the size or so, of the ECU.
Old Aug 5, 2009 | 05:20 PM
Mervin's Avatar
5SpdH22 is right - my instructions are for a 4th gen RHD Lude.
Hope there isnt anything very different or that i put you on the wrong track
GL!
Old Aug 6, 2009 | 12:58 AM
HondaVerno's Avatar
that little thing hanging on the cable connected to the pedal looks like a little baton shape metal piece. you sure its just a twist n pull out? ive tried it for awhile and just gave up. help meeeee!!!
Old Aug 6, 2009 | 09:34 AM
Enzo15's Avatar
Theres a vac line that needs to be capped. A couple 10mm bolts hold the CC unit in place in the engine bay. The vacuum tank gets taken out of the fender well. As far as the throttle cable goes, its a little awkward to get under the steering wheel/dash, but once you do, push the gas pedal in a little, and the CC cable should stick out a little. When it does try to pull on it a little, and you should see where it hooks onto the gas pedal. Twist it out of the way and it should come out. After thats done there should be a grommet holding it in place on the firewall, that should just come out after you turn it. Also the FAQ has this information, and my Prelude is a 4th gen with no intentions of being a daily driver or going on long cruises, so I took it out for less weight and more room to move in the bay. Hope this helps someone.
Old Aug 6, 2009 | 05:01 PM
Its pretty much the same concept rhd and lhd ill figure it out. thanks
Old Aug 7, 2009 | 10:59 PM
HondaVerno's Avatar
damn this thing is really hard without pics...mind posting some on my behalf? hahaha thanks in advance
Old Jun 14, 2012 | 01:55 PM
PreClude's Avatar
I know, I'm bumping an old thread. But I need some help. Here is my thread on my 5th gen CC delete: https://honda-tech.com/forums/honda-prelude-4/cruise-control-delete-5th-gen-pics-question-3064457/
But here are some pics and a bit from that thread that I need some help on:
I wonder what this thing is. It seems to be part of the brake system somehow maybe. Since it looks connected to a brake line. Maybe it was so the brake system could interface with the cruise control, etc. Wonder if it's needed anymore? Since it's not actually hooked up to anything now.
I capped off that hose that went to the bottom down underneath the large canister. Hope that's OK lol.
Taped off the electrical connections and secured and tucked them away as best as I could.
This part here concerns me though. I can't seem to figure out WHERE it might have been connected before I started tearing stuff out. Unless it was just like this all the time, I don't know. It does seem to be hollow in the top and down into the tubing so I'm guessing it vented/went somewhere, unless it was just to atmosphere. I capped it off, but I really hope I didn't screw something up here????
nails
Aug 17, 2019 03:31 PM
marcus81184
May 12, 2009 09:05 AM
sd_ej1
Dec 30, 2008 09:30 AM
vtecpsyco
Jul 31, 2004 03:12 PM
SOHC_MShue
15
Sep 24, 2003 11:10 AM
