Skunk2 manifold installed no runs like crap
put a long story short i installed a skunk2 manifold yesterday on my 98 gsr and everything hooked up correctly i assume the only thing i was not sure off was on the oem manifold there is the diaphram for the secondaries which does not exist on the skunk to so i capped the vac line going to the canister under the manifold.
Car runs like its bogging and i it makes a whistle type sound when its bogging. idle is a little lower so ill bump up the idle but i know thats not the probem... any suggestions?
thanks
thanks
it's 4400 rpm and the stock ecu timing curve isn't really THAT bad. the a/f you can adjust with a scan tool or wideband and an fpr. a few common things people do here that cause problems are
1. not clean all the old gasket off the head.
2. use cheap new gaskets that don't seal
3. not change the TB gasket
4. switch the map and tps plugs
5. not clean the injector bosses or wipe grime off the injectors thus causing another vacuum leak at the injector
6. not tighten the manifold to the head tight enough
you can get a very slight improvement with a chipped ecu that's running a program for the gsr with a single runner manifold. however, i would just use the stock and save my money for a real tune when you get the cams and compression to go with it. an fpr and some way to read AF like mentioned above will have the car running great.
there is no way you could ever reuse the old manifold gasket without a leak. 99.9% sure that's your problem. why in the world did you go through the labor of doing this without new gaskets? you should have been able to tell visually they would create a leak
not sure if i agree with you on this one, i have reused plenty of gaskets on bikes and cars without problems. The TB gasket was the one that was visually in good condition the IM gasket on the other hand had a tear near the coolant port which i RTV and no leaks however there is a problem. I have to test a few things still but in terms of what is plugged into what yes they are all correct i have the wire diagrams with colors matching the correct sensors and putting the tps sensor on the map sensor the car dies flat on its face past 5% tps. I'm skeptical the issue is the IM gasket but i could and hope im wrong. live and learn if it is the problem.
your right about the IM gasket i was not expecting it to be as bad so when i put it back together i was hoping for the best.. i really do hope that is the problem.
for some reason the TB whistles with this manifold. you can kind of quiet it down if you pull the TB and use a sanding roll on the die grinder to texture the surface. sort of like porting the TB without removing much material
jetspeedz
145
Dec 18, 2009 07:29 PM
