01 gsr rear brake spindle question
i took the front and rear brakes off a 00 gsr to switch over to my 99 hatch, on the driver side rear spindle one of the torx bolts broke off endin up making it useless...my questions is would any other regular integra rear spindle 94+ work with my gsr calipers
You should be able to use any spindle from 90 to 2001 as long as it has the ABS sensor mounting. I would take your old spindle to an automotive machine shop and have the bolt drilled out. It seems like the easier of the two options.
i tried about everything and had no luck..i tried to weld a bolt on it with no luck, cut a groove and tried a big flat head only to strip the hole head off, then i took it to a automotive shop and he had no luck, but thanks for info i believe i have a spindle lined up
I believe you man those bolts are tough. The problem is that its a taped through hole so water and grim gets into the threads and makes it impossible to remove.
philosofy1
Mar 29, 2007 08:31 AM
allicedout
Mar 27, 2004 09:54 PM
