99 civic b16a2 swap radiator problem...please help me.
Old Aug 2, 2009 | 07:18 AM
SilvrCiv99's Avatar
Default 99 civic b16a2 swap radiator problem...please help me.
I am doing a b16a2 swap in my 99 honda civic lx and also a 5spd conversion...I am almost done but the radiator hoses off of the b16 won't fit the radiator inlet and outlet pipes on the radiator, the hoses are too big and the ex goses won't work if I bought them because the sohc motors have the inlet for the radiator is on the front of the block and on th b16 it is on the side....what can i do to make the hoses fit, or will i have to but an upgraded radiator?
Old Aug 2, 2009 | 07:25 AM
natsuke's Avatar
Default Re: 99 civic b16a2 swap radiator problem...please help me.
You could always take your hose that you have and go to an auto parts store with the measurement of the inlet and outlets of the rad and ask them if they have any hoses with similar shapes that have the right sizes that you need. If not you could try and find a step down hose that has a smaller end that would on the rad side. You would have to buy a metal coupler and some hose clams and cut the old hose slip the coupler in and put the step down on the other side. Kind of a pain to do but if you can't find anything you might have to do that.
Old Aug 2, 2009 | 09:31 AM
98civdx's Avatar
Master Detailer
you can use them you just have to get that clamp on there hella tight.
alot of people have done it.
or just try and find a civic si rad. oem is fine, i got my oe replacement for 100 new.
Old Aug 2, 2009 | 10:07 AM
silverbullet9626's Avatar
you would be better off buying a dual core for a b series from cx racing off ebay(65$) thats what i did on my swap and it cools like a dream
dsol
Jun 27, 2017 10:21 AM
dcraige
Jun 24, 2010 07:43 PM
streetracerof06
Feb 13, 2006 01:14 PM
spoonek4
Jan 12, 2006 11:41 PM
streetracerof06
Nov 5, 2005 11:21 PM
