Transmission & Drivetrain Gearboxes, Differentials, Clutches
GSR gear set in a LS transmission???
Old Aug 2, 2009 | 05:57 AM
Dirty_SL8's Avatar
Default GSR gear set in a LS transmission???
I have a LS swap in my 96 civic dx and wish to have a bit better acceleration. I also have a set of GSR gears at my disposal (my trans is non lsd as was the trans the gears came out of). My question is this...... can I put a GSR 3rd and 4th gear in my LS trans and keep the long LS 5th? I know a guy at my local shop that did this in a cable trans, but he says he is unaware if it can be done in a hydro. Thanx you
Old Aug 2, 2009 | 06:36 AM
sloweredcivic's Avatar
Default Re: GSR gear set in a LS transmission???
I believe it can be done, either way here is a handy calculator for swapping gears.
http://www.fatboyraceworks.com/gears/
Old Aug 2, 2009 | 10:36 AM
Aquafina's Avatar
Yep. But you'll need to use the GSR 3/4 hub/slider/synchros and shift fork.
Old Aug 2, 2009 | 03:11 PM
Dirty_SL8's Avatar
Thank you both for responding. Ill have to see if I can source all of those things.
Old Apr 11, 2011 | 08:23 AM
diablo2184's Avatar
did you ever finish doing this?
steveharrmr23
Oct 1, 2008 03:18 PM
Will_H
Jul 25, 2008 09:33 AM
88 yellow crx
Feb 25, 2007 06:38 PM
92HB_HB
Feb 28, 2003 01:00 PM
Arsenal
Jul 20, 2002 10:32 AM
