Burning oil ? valve cover gasket ? Need HELP PLEASE ;(
Old Aug 2, 2009 | 04:32 AM
jdmjoka's Avatar
DB squad #282
Default Burning oil ? valve cover gasket ? Need HELP PLEASE ;(
Ok, Here's the deal. I bought another gsr 4 door integra. (1994) The motor seems to run quiet with NO taps or anything odd, Here's my concern. When i pull spark plug wire number 4 Theres oil down in there? Whats causing that? and could that reflect, when i check my oil and it beeing lower then it should? I bought the car 3 days ago and it seemd to use a lil bit of oil in 3 day's. Also. I smell a burning oil smell (not bad and rarley). and the car has a straight pipe no cat, could that cause the smell? or could it be the oil in the plug wire. My main question is, How do i fix the Oil in the spark pplug wire. and would that stop the car from losing oil.? and possibly the smell
and the car has NO BLOW bye when you take the oil cap off at idle. Is that good?
Thanks ahead.
Old Aug 2, 2009 | 04:39 AM
jdmjoka's Avatar
DB squad #282
Default Re: Burning oil ? valve cover gasket ? Need HELP PLEASE ;(
Any body?
Old Aug 2, 2009 | 05:12 AM
SleeperGSR's Avatar
i would check and make sure all the bolts are torqued correctly first.
Old Aug 2, 2009 | 05:28 AM
jdmjoka's Avatar
DB squad #282
I've checked those this morning.
Old Aug 2, 2009 | 10:28 AM
trueblood's Avatar
get a new valve cover gasket set. the round gaskets are more than likely hard from time. Once hard they dont seal. dont forget to use a dab of RTV sealant in th corners on the head by the cam seals.
Old Aug 2, 2009 | 10:41 AM
SleeperGSR's Avatar
pretty sure the valve cover gasket would have nothing to do with oil around the spark plugs, they have their own seals. There is a full valve cover kit at inlinefour.com for like 45$ for all the seals
Old Aug 2, 2009 | 10:56 AM
StolenTeg's Avatar
There are four round gasket that seal the spark plug holes, those gasket are leaking
Old Aug 2, 2009 | 10:59 AM
GSaura's Avatar
The valvecover gasket set includes the four oring seals that seal off the spark plug tubes. You can't buy the tube gaskets separately. If you were local I'd give you one.
Old Aug 2, 2009 | 12:40 PM
dc2teg99's Avatar
valve cover gasket bro.... but you still shouldnt see a difference in oil level if its only leaking from there... there still might be something else ....
Old Aug 2, 2009 | 01:02 PM
jdmjoka's Avatar
DB squad #282
Thanks guys, so thats the valve ocver gasket, NOW does that also explain the mild smell of oil? rarley when im driving? or would it be the straight pipe all the way back causing that?
jdmjoka's Avatar
DB squad #282
and a bad valve cover gasket couldnt cause no loss in oil when i check it? for sure?
Old Aug 2, 2009 | 03:06 PM
JonMaltese/LScivic's Avatar
do you see a big cloud of smoke behing you when you floor it??
Old Aug 3, 2009 | 06:42 AM
jdmjoka's Avatar
DB squad #282
only in vtec, but i dont see the rings being bad if the compression is 190 and no blow bye? thats where i get confused
jdmjoka's Avatar
DB squad #282
it has no cat tho all straightpipe so could that be it?
Old Aug 3, 2009 | 11:12 AM
well vtec= floor it, so the answer is yes you do see smoke when you vtec lol it could be the oil control rings that are going, you can still have good compression since the compression rings are ok
Old Aug 3, 2009 | 11:13 AM
its the shitty sludge and deposits that clog up the rings causing them not to work good,, so if you ALWAYS change your oil yuor engine can last really long..
Old Aug 3, 2009 | 11:49 AM
90_EX_Civic's Avatar
valve seals?
Old Aug 6, 2009 | 09:27 PM
jdmjoka's Avatar
DB squad #282
i just figured out when i floor it the smoke is white.... theres no cat. fresh oil change so you guys think its the oil control rings? or valve seals? how hard of a job would those be?
Old Aug 6, 2009 | 09:34 PM
jdmjoka's Avatar
DB squad #282
some one please let me know what it would cost for new valve seals and oil control rings and stuff like that and how hard it would be, also are you guys kinda positive thats what the smoke is from
Old Aug 7, 2009 | 05:26 PM
xantavar's Avatar
def valve cover gasket and spark plug tube rings....
oil could be dripping down slowly from the bad valve cover gasket causing the smell...
Old Aug 8, 2009 | 06:59 AM
Spawne32's Avatar
seems these things warp very easily, i just need a valve cover gasket, spark plug tube seal job on mine and torqued it to spec and it was leaking out of the front by the #4 exhaust cam lobes, dont know why, but i torqued it down further to 90inch pounds and it stopped.
jakop92
Nov 15, 2009 11:33 AM
keilux
53
Aug 17, 2009 05:43 PM
sdinteg
Mar 27, 2005 09:22 PM
djmatix
Feb 7, 2005 07:58 AM
shingles
Dec 22, 2001 07:28 AM
