2000 civic ex!!!!
Old Aug 2, 2009 | 01:12 AM
00BlackBeauty's Avatar
Default 2000 civic ex!!!!
HELLO all i am new to this so please help and not criticize I have a civic ex with a d16 y8 and was told that if i put a gsr ecu on my car it would make it faster... Is this true and if so which ecu do i look for? and will this enable my vtec cause right now it is not kicking in at 5500 rpm.
Old Aug 2, 2009 | 01:29 AM
Davus's Avatar
Default Re: 2000 civic ex!!!!
It is not true, unless the GSR ECU came with a motor too.
As for VTEC not engaging, do you have any check engine lights, low oil, and the correct ("P2P" labeled) ECU in the car?
Old Aug 2, 2009 | 01:30 AM
Linked's Avatar
no, on the contrary, you'll blow your motor....
and dont take it lightly, you will kill your motor
lol hell am i kidding , the car wont even turn on
you need a compatible ecu with your motor, just cant throw a different ecu from a faster motor onto yours.
you CAN chip your ecu, and remove the rev limiter, make the vtec switch over at an early rpm etc etc
Old Aug 2, 2009 | 01:31 AM
!IShockedURMom!'s Avatar
Haha. Whoever told you that you need to Bitchslap THEM!
Old Aug 2, 2009 | 10:10 AM
LOL Okay i thought so.. and my car runs fine no low oil, no check engine lights and i dont know about the p2p i will check it out. I have another question also. is a b20 block with a b16 head a good swap just for a overall power increase just trying to go faster but not spend alot of money?
Old Aug 2, 2009 | 10:29 AM
98civdx's Avatar
Master Detailer
yes a b20 with b16 head will do pretty damn good, only for a while tho, if you dont build the block do take highier rpms youll blow it.
do some reserach, a ls or b20 vtec is a tickng time bomb if its not properly built
Old Aug 2, 2009 | 03:38 PM
thanks alot.
Old Aug 2, 2009 | 04:02 PM
SoullessJapaneseMachine's Avatar
you can chip EK ecu's?
Old Aug 2, 2009 | 09:41 PM
98civdx's Avatar
Master Detailer
^^ yes you can, but your going to want to get a obd1 ecu, they are alot easier to tune.
Linked, you can and the car will run,
my buddy put his chipped p28 for his b16 on his d16 and it ran, hit vtec and all.
Old Sep 21, 2009 | 10:29 PM
JDM.K24's Avatar
Yes you can chip them.
Old Sep 22, 2009 | 10:12 AM
Well how can i link the ecu's? What do you mean by that? And wouldn't I blow my engine if i had a Dohc ecu running a Sohc ecu?
Old Sep 22, 2009 | 12:33 PM
JDM.K24's Avatar
It's called a Jumper harness. You need one from OBD1 to OBD2. And yes you could blow your motor if you ran a b-series ECU...
Old Sep 22, 2009 | 12:35 PM
FaTBoY707's Avatar
well its all been said already but yeah ...... that would be stupid
Old Sep 22, 2009 | 06:26 PM
Under what circumstances would you blow your motor? Every day driving or just punching it all the time?
Old Sep 22, 2009 | 06:47 PM
tEKnics's Avatar
At what point would u wanna run a b-series ecu if u have a functioning ecu for that motor. To me it seems like a waste of time and money. What do I know tho. Just see absolutely no real good purpose.
Old Sep 22, 2009 | 06:56 PM
rehaf's Avatar
Dude there are way too many reasons NOT to attempt to put a b series ecu on your d16. If you want more power try a few bolt-ons. You're not going to get alot out of a sohc without spending a bucket of money and/or boosting it anyway. As for your vtec, I have a '00 ex and believe me it's not that impressive at 5500 rpm either...
Old Sep 22, 2009 | 07:29 PM
D Griff's Avatar
yeah... D16's are just unimpressive regardless, I've spent money on bolt ons for mine... not really worth it, save it for a swap or turbo or just settle for your 110 hp and 40 mpg
Old Sep 22, 2009 | 07:43 PM
jyacoba2009's Avatar
part for part.. d16y8 is cheaper and more powerful from the 200+ hp range.. until about 300.. if you want a relative easy, cheap, and faster car.. stick with sohc, but if you wanna go faster.. go with a b series
Old Sep 22, 2009 | 09:27 PM
98civdx's Avatar
Master Detailer
runing a sohc motor wouldnt do noithing for a sohc, and it wouldnt run good,
Old Sep 22, 2009 | 10:36 PM
Thanks for all the replies... Its just im trying to save for a swap but i dont know what the different motors have to offer. For Instance
The LS swap what is its benefits also what tranny would/could be used
The b16 swap what is its benefits
The b18 swap what is its benefits
The b20/b16 swap what is its benefits
Just the b20 vtch vs non vtech swap?
Wat is the best tranny to use?
Out of all the swaps which will give you the more significant gain in power and torque but wont hurt your pocket? I am looking for more power gains with no boost. I currently have the d16y8, which you all no.
Old Sep 22, 2009 | 10:51 PM
biostarled's Avatar
actually your an idiot i ran a single cam ecu and my b16a and i also ran a p30 on my d15b. wow your a f'n idiot learn your hondas. hahaha take your *** of this site or read a f'n book
Old Sep 23, 2009 | 06:11 AM
b18-c type-r is your best swap.. its pricey, but highly compatible with a lot of things
Old Sep 23, 2009 | 11:11 AM
Well you sound pretty smart? i am currently have the p2p ecu which is the best ecu i can put on there for a little more gain??
Old Sep 25, 2009 | 08:54 AM
Whats a good set of springs to buy that will get me a descent drop but not to low and too bouncy
Old Sep 25, 2009 | 09:43 AM
Vindicator9000's Avatar
318 Curves, 11 miles
The P2P. Just because an engine will run on other ECUs doesn't mean that it will run the best on them. The only reason that you would run a different ECU than intended by Honda would be that you were going to socket, chip, and tune it.
As far as your question about relative pros and cons on the engines... it goes something like this: some have more horsepower, and are either more expensive, harder to swap, illegal, or all of the above.
here's a nonexhaustive list of engines from least to most desirable:
B18 (LS) / B20 (CRV): different engines. LS tends to be more reliable, B20 has more torque stock. B20 is technically illegal in a Civic in many places.
B16a: +/- 160HP. around 2500 from hmotors.
B18C1/2/3/4: +/-170-180 HP. more torque than B16. 2800-3200 from hmotors. Stock in Integra gsrs. Intake manifold not interchangable with other B series
H22: about 200 HP. Relatively cheap... maybe $1500-2000. Fairly difficult to swap since Civics were never intended to have H22s.
B16b: 185HP. not much more torque than B16a. Very expensive. Made to rev. $3500-4K from hmotors.
B18C5: 190HP. Stock in Integra Type R. Usually slightly cheaper than B16b, bit easier to find. $3400-3600 from hmotors.
K20/24: Plan to pay $8-10K. Lots of power, rare, but not worth the $$ IMO.
