headgasket question... plz help...
Old Aug 1, 2009 | 09:34 PM
crxboy909's Avatar
Default headgasket question... plz help...
ok so heres the problem... i recently did my headgasket and i followed each step by stepp... i finished the car started right up but i have no power at all while driving cars bogs horribly... the car car is not throwing smoke or anything but after a while of starting up my oil leaks from between the head and the blockk. i brought the head to a machine shop to get resurfaced and i did the torque specification to 67 ft pound...... so here is my question... is it possible that the head got resurfaced un evenly?? have this happened to anybody before??? plz help....
Old Aug 1, 2009 | 09:38 PM
Since 1983's Avatar
Default Re: headgasket question... plz help...
anything is possible, not sure of the tq specs on the head gasket tho, id recheck and go from there
Old Aug 1, 2009 | 09:40 PM
crxboy909's Avatar
yea thats the specs that i got from a friend... cause he recently did a mini me swap on his crx....
Old Aug 1, 2009 | 09:43 PM
Davus's Avatar
Did you do incremental torquing (like 15, 30, 60+) with new head bolts?
Old Aug 1, 2009 | 09:47 PM
crxboy909's Avatar
yea i did... but not with new headbolts.. is it recommended to get new headbolts??
Old Aug 1, 2009 | 09:52 PM
Since 1983's Avatar
its always a good idea, but not always a necessity
Old Aug 1, 2009 | 09:58 PM
crxboy909's Avatar
ok so did some research and i had no idea that you also have to torque 1&2 one last time... lol well ima just give that a try and see wat happens... thanks for the help everyone =]
Old Aug 1, 2009 | 10:02 PM
R.coustom's Avatar
thank u for your help on my tread . I recently did a head gasket job on my friends car now. did you follow the 4 steps torque spec? are u using ARP studs or did you used OEM head bolts? , Did you set your timing mark right cuz if not that could be it.
Old Aug 1, 2009 | 10:14 PM
crxboy909's Avatar
im using the oem head bolts and yea i did followed the 4 step but what i didnt do was go back and torque 1&2 one last ime or is that not necessary? and yep the timing was just barely off but it was on...
Old Aug 2, 2009 | 06:31 AM
TLo's Avatar
TLo
copper spray is your friend, even with copper spray the there still might be some leaks, also if you you are having bogging problems it could be because of the timing, which usually results in you having to do the timing belt again.
Old Aug 2, 2009 | 12:00 PM
R.coustom's Avatar
any progres on the car
Old Aug 2, 2009 | 08:50 PM
crxboy909's Avatar
ok so i tried to torque 1 & 2 down one last time... and it still leaks from between the head and block.... =[
Old Aug 2, 2009 | 09:01 PM
crxboy909's Avatar
so anymore ideas of what i should do??? or should i just buy a new head and go from there?
Old Aug 3, 2009 | 04:13 PM
SiRkid1's Avatar
bump hope you find a solution.
Old Aug 3, 2009 | 04:15 PM
crxboy909's Avatar
thanx man... anybody with any ideas???? need my car running asap
Old Aug 4, 2009 | 12:54 AM
crxboy909's Avatar
any suggestions?
Old Aug 4, 2009 | 07:05 AM
sde780's Avatar
hows your ignition timing and mechanical timing? if your a little off itll run like ****. what kind of headgasket did you use, did you follow the torquing order
Old Aug 4, 2009 | 07:14 AM
angel_i's Avatar
Ignition timing should be checked along with mechanical timing. I would blame the used headbolts if everything else checks out.
Old Aug 4, 2009 | 07:34 AM
sde780's Avatar
did u soak em in oil before reusing?
Old Aug 4, 2009 | 04:22 PM
crxboy909's Avatar
ok so thats two people who says used headbolts is the problem... well im gonna try changing them then and see what happens... and no i did soaked them in oil.. is that recommended?
Old Aug 4, 2009 | 04:27 PM
crxboy909's Avatar
oh and the headgasket i used was a fel-pro brand....
Old Aug 4, 2009 | 04:42 PM
1992Si's Avatar
Only use OEM HG's or may be cometic.
As I was reading this, I was thinking, what HG did he use ?
Old Aug 4, 2009 | 05:00 PM
crxboy909's Avatar
how much is the oem headgaskets?? cause i paid about 60 for the fel-pro and i was told that it meets the requirments of a oem one....
Old Aug 4, 2009 | 06:07 PM
bryse68's Avatar
sounds like a timing problem, oem head gaskets are about 125, fel-pro is not the way to go..........
DaYZeD.1
Mar 28, 2008 09:19 AM
2-logicl
Mar 27, 2006 07:04 PM
fe519
Sep 13, 2005 04:30 AM
ScubaStevo80
Jan 11, 2005 01:08 PM
