what to do with metal tube from VC to intake
Old Aug 1, 2009 | 07:46 PM
young geezer's Avatar
Default what to do with metal tube from VC to intake
i want to remove the metal tube from the valve cover to intake out but what do you guys with the other hose under the intake manifold?
Old Aug 1, 2009 | 09:32 PM
toyomatt84's Avatar
Sanji
Default Re: what to do with metal tube from VC to intake
Knowing what kind of car you're talking about would be most important to answer this kind of question.
Old Aug 2, 2009 | 12:16 AM
Arthas's Avatar
Put a breather filter on VC and plug intake hole.
Old Aug 2, 2009 | 12:44 AM
hybrid90's Avatar
I thought breather filters on a VC is a no no... aren't those for domestics?
Old Aug 2, 2009 | 01:11 AM
Arthas's Avatar
I have no idea but id love to know. I currently have a breather filter on my VC.
Old Aug 2, 2009 | 02:11 AM
slowman's Avatar
I took way too long
I had a breather filter on my old sohc turbo for years. no problems. and with the other tube, that's a coolant line. so you either remove the entire thing (valvecover to intake and coolant line) or you have to cut them apart. makes more sense to remove it all as one, and replace with necessary hoses. that's what I have done on my EM1
Old Aug 2, 2009 | 03:06 AM
1ac4u2nv's Avatar
Breather =Bad
The honda crankcase breather is a POSITIVE pressure ventilation system.The air from the intake blows into the valve cover. It is NOT a negative pressure ventilation system...it does NOT suck air from the valvecover to the intake.
Breathers remove the source of positive ventilation that repressurizes the POSTIVE CRANKCASE VENTILATION (PCV) valve.
There is less pressure in the crank when you add a breather at the valve cover. The consequence of this is you get more positive blow-by from the combustion chamber past the piston rings and into the crankcase. More blow-by means less cylinder pressure...less cylinder pressure means the burn is slower and less complete...the result is more emissions and less power. **Taken from Prelude online.com**
Old Aug 2, 2009 | 03:26 AM
95DC2GS-R's Avatar
Cut the metal tube into a 2" section, and use the hose to and from it. Solved.
Let me know if you need a pic..
Old Aug 2, 2009 | 09:33 AM
donut.'s Avatar
Originally Posted by 1ac4u2nv
Breather =Bad
I learned this the hard way
Old Aug 2, 2009 | 09:42 AM
yah mum's Avatar
correct me if wrong but isn't it a negative pressure because its before the throttle body?
Old Aug 2, 2009 | 10:43 AM
i am kinda lost can you post a pic if you dont mine. thank you.
Old Aug 2, 2009 | 11:13 PM
95DC2GS-R's Avatar
Right under my hand..
Old Aug 2, 2009 | 11:17 PM
hybrid90's Avatar
Breather =Bad
Yeah that's what I thought.. I knew I read about this somewhere before... thanks for clarifying that..
Old Aug 3, 2009 | 02:34 AM
1ac4u2nv's Avatar
No problem. I've made the breather mistake once... : (
m0squ1t0
Sep 6, 2009 10:00 PM
andyp
Jun 7, 2004 05:12 PM
vinuneuro
Nov 2, 2003 05:09 AM
pelotudo
Aug 27, 2002 07:15 AM
fo-do
Jan 10, 2002 12:47 AM
