New H22, broken sensors!!
[IMG]
[/IMG]
what part is this? i just got my H delivered to day and saw this and the next pictures part is broken.
[IMG]
[/IMG]
this parts also broken, jus wanna know what they are so i can replace them. thx
[/IMG]what part is this? i just got my H delivered to day and saw this and the next pictures part is broken.
[IMG]
[/IMG]this parts also broken, jus wanna know what they are so i can replace them. thx
yea.. the box one sits below the Intake Manifold, and is held on my 2 bolts.. has 2 hoses into the side as well as a connector.. and looks like it had 2 hoses on the other side as well... and i just bought a Blox Tps sensor off ebay.. hope they are good.
Just make sure you calibrate the TPS when you put it on. A quick search and you'll learn how.
yea for sure i looked in a swap book i had its called the "Vacuum Box" for the IAB.. havent really seen any for sale alone... checked ebay.. i didnt see any or i guess i suck at searching.
*(Just make sure you calibrate the TPS when you put it on. A quick search and you'll learn how)*
for sure, oh and if i get a P72 ecu i dont have to worry about the box do i? or do he Gsr's use the butterfly valves too?... i was told i can jus get the 72 and put an h22 basemap on it. ty for the help in advance.
u really dont need the vacuum canister or the butterflys.. they only help with very low rpm and daily drivin..if u dont hook up and vacuum to the butterflys they will run open all the time
