Cluster Gauges Not Working?!?!?
RPM, MPH, Fuel, and Engine Temp Gauges do not work. Along with my turn signals. The backlight lights up, but none of the gauges are operational. Checked all fuses (under hood, and dash) Fine.
What else could it be?
Thanks
Thanks
Got another ? for ya. When I go to start my car you hear the starter click adn hit the flywheel but doesnt start. Do it a 2nd time and it starts.
Any suggestions?
Any suggestions?
Is the battery fully charged and the battery connectors and ground wire tight and clean? Are the two starter connections likewise clean and tight? If all is fine, the starter motor may be failing. You also might want to check for damaged teeth on the starter gear and flywheel. Another possibility is a faulty starter switch at the top of the clutch pedal.
Battery is brand new, terminals are fresh. I just went and had the starter tested at a shop PASSED. Teeth on gear and flywheel fine. I'll take a look at the starter switch and make sure connections are clean and tight on the starter.
littlebill
May 22, 2007 02:09 PM
EnKidu
10
Jul 17, 2006 02:05 PM
