2000 Si Clone problems
Old Aug 1, 2009 | 01:16 AM
jkalex05's Avatar
Default 2000 Si Clone problems
I have 1996 with a 00 USDM B16A2 swap, it has 60k miles. However I am having some issues with the car.
1) First off my idle on my car is really weird. When I start the car it starts really low and then goes up to about 1800 and slowly goes down. Usually when im driving my idle will be between 900-1200. I also notice when I turn on my SA my idle goes weird and drops down to like 700.
2) My passanger window got stuck halfway up and stopped working im preety sure its the motor since neither switch works but my driver window works with no problem
3) My shift **** has lots of play it vibrates bad, im preety sure the tranny/motor mounts are worn and im planning on purchasing some Hasport mounts, I can install this myself right all I need is a good jack and some wood to put inbetween right and tools of course.
4) When I turn on my AC the car starts rumbling bad and its the only time my car idles at 800.
Any input would be appreciated.
Old Aug 1, 2009 | 02:57 AM
yoej8's Avatar
Default Re: 2000 Si Clone problems
With problem 2... did you check your fuses. And second... are you sure you didn't accidentally leave the window lock function on the driverside controls?
Shift **** rattle... could be motor mounts indeed...check them out... if they are ok, change out the shifter bushings.
AC on = rumbling bad.... Most likely the motor mounts are busted after all.
Good luck... keep us posted
Old Aug 1, 2009 | 04:27 AM
RamoncilloSI's Avatar
some energy suspension bushings for the linkage would be nice.
Old Aug 1, 2009 | 05:40 AM
JasonYo's Avatar
I would recommend getting some new shifter bushings, makes a big difference.
you should be able to do the motor mounts yourself, just depends on how competent you are.
And yeah, check the fuse for the passenger window
Old Aug 1, 2009 | 06:44 AM
HondaGuy951's Avatar
problem # 3--Shifter Bushings!
problem # 1--Try Replacing Your Idle Air Control Valve and go From There!
problem # 2--96-00 Civic 2Drs are Notorious For the Windows Coming Off Track. Is The Window "OFF"? Like Rolling up Weird? Can you Roll it Down, Just not up? If You get Nothing at all, Check Fuses and Window Switch Itself!
Hope This Helped!
Mishako129
May 18, 2013 07:34 AM
6footmidget
11
Mar 10, 2009 07:20 PM
shraz
Honda Civic (2006 - 2015)
Jan 13, 2009 10:33 AM
vi3tromanc3r
Mar 31, 2007 02:06 PM
sleepyhamsterlx
Dec 4, 2003 07:35 PM
