help neutral switch
ok i need help wiring the neutral safety switch i bought a cabin harness they told me it was for 5spd and it wasnt so i tried wiring it to the ecu blue wire to b9 the starter signal and black to ground but it still wont work (by the way i have a 94 civic) im tired of touching the starter post just to start the car any help would be great
i just did a auto to 5 speed swap. on the auto connector, there are 2 wires on the harness that go to the shifter (the two big ones are the neutral safety switch) the top ones are the reverse lights)
check this out for the wiring part. (instead of running the wires to the clutch. you CAN just connect them together. but the clutch is safer.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-my-auto-manual-swap-pics-56k-no-no-2090074/
well you can always do this.
i just drew that real quick.
Find the wire on the key switch that has 12volts + when the key goes to start. then cut that wire, and run it to number 85 on a bosch 4 pin relay. then ground out pin 86 on the relay.
wire up pin 30 to the positive terminal on a battery (with a 20 amp fuse) and send pin 87 to the starter solenoid (the terminal you touch with a wire to start the car the way you are now)
and instantly you have a cheap starter switch that looks factory.
i recommend no less than a 12 gauge wire. 10 gauge preferably
ferio-ichi3
Apr 2, 2013 01:46 PM
VI Boost
Dec 18, 2008 01:54 PM
