headunit only has power if parklights are on!!!!!!!!!!!!!!
Old Jul 31, 2009 | 06:37 PM
damn_import_culture's Avatar
Default headunit only has power if parklights are on!!!!!!!!!!!!!!
what title says head unit only turns on if parklights are on on my 93 accord the power antenna seems to be a aftermarket replacement and may have something to do with this but other then that i have no other ideas because headunit is wired correctly as far as i know
Old Jul 31, 2009 | 07:02 PM
It Wasn't Me's Avatar
Default Re: headunit only has power if parklights are on!!!!!!!!!!!!!!
If it was wired correctly it would come on when you turned your key, or after you started your car. Someone wired it the wrong way.
Old Aug 1, 2009 | 06:06 AM
well this car has had some hack wiring done so im working with **** but thanx for the answer captain obvious anybody else have some ideas?
Old Aug 1, 2009 | 06:54 AM
1. Don't be a smart *** when someone provides relevant input.
2. Obviously it's not wired correctly. You seem to think it is. That was my point.
Moving along...
Old Aug 1, 2009 | 07:05 AM
no the headunit is wired correctly and whoever ****ed with this power antenna somehow ****ed up the power to it and the headunit
Old Aug 1, 2009 | 07:08 AM
fcm's Avatar
fcm
Old Fart
The HU "switched power" lead, [red] is connected to the stock radios illumination lead, [red/black] in stock radio harness, instead of the acc. lead in the stock radio harness, [yellow/red], and if it is wrong I would check the rest of the wiring of the HU...
http://www.installdr.com/Harnesses/HA-Wiring.pdf 94
Old Aug 1, 2009 | 07:24 AM
^^ I was just thinking about that while I was .. um .. nature called.
Old Aug 2, 2009 | 01:18 AM
EG'SUS's Avatar
LOL, turns on when the lights are on?? they probably wired the remote or power cable to the light cables
Jsl9299
Nov 11, 2018 12:15 PM
skyleraustin
Apr 21, 2015 01:02 PM
h22dx
Feb 9, 2011 05:08 PM
grilledcheese33
Audio / Security / Video
Jul 23, 2008 08:43 AM
GroundZer0
Dec 19, 2003 03:48 PM
