h22/h23
hey wassup i jus wanted kno wats the specs on a h22 head an h23 block has anyone ever done dis swap b4 an if so what changes must b dont in order the bolt the two up together. how much power am i lookin at? thanx
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/time-my-h23-vtec-build-dd-2525420/
this is the latest h23 vtec thread i could find.
the only difference wit h22 block the type S the 11:1 piston, h22a4 10:6:1 piston wit a 90mm stroke crankshaft and the h23 block 9:8:1 piston wit a 95mm stroke crankshaft..
H22a vtec- 220hp 163 lbs ft tq.
H22a1 vtec- 190 hp 158 lbs ft tq.
H23a- 160 hp and 156 lbs/ft tq.
This is wat i did to my h22 vtec i took the head & put it on h23 block
H22a 87mm bore 11:1 piston and place them on to the h23 rods
and since the h23 stroke is high 95mm and the rods are a lil bit taller
it bump my compression ratio up so it somewhere around 12:6 or 12:4
and the car halls ***..
you can also do it this way and the car runs harder used the h23 95mm stroke crankshaft and rods wit the h22 pistons 11:1 or the 10:6 AND PUT IT IN THE H22 BLOCK & THE VTEC HEAD COMPRESSION WILL BE HIGHER THEN 12:6 NEAR TO 13:
pkolaboy
Feb 19, 2008 06:37 PM
