is wheel spacer needed for wheel offset
Old Jul 31, 2009 | 04:26 AM
civicboy1128's Avatar
Default is wheel spacer needed for wheel offset
i have a 05 rsx type-s and im thinking of getting a set of 18x8.5 volk te37s with a plus 22 offset, but dont know if i should need a spacer or not. anyone running a similar setup with info would be greatly appreciated.
Old Jul 31, 2009 | 05:16 AM
josh's ep3's Avatar
Function > Form
Default Re: is wheel spacer needed for wheel offset
No you shouldn't. For the most part it depends on the wheel. Also, most higher offset wheels usually +40 and above will tend to need a spacer. Google how offset works and you will understand why. 18x8.5 +22 will sit super flush with your fenders, I think that would look pretty sick. I can almost guarantee that you will need a slight fender roll though. Look on CRSX.com and check out the Aggressive Wheel thread. There will be plenty of RSX's there with wheel specs close to that.
Old Jul 31, 2009 | 08:33 AM
H82L0S3's Avatar
New User
LOL no u dont, 22 offset is good enough
Old Jul 31, 2009 | 11:44 AM
archull's Avatar
Those wheels will be sticking outside your fenders. I hope that you are not very low.
I am running a set of Volk CE28N's in 18x8.5" +40mm offset wrapped in Nitto Invo tires (255/35R18) and they are sticking out a bit from my fenders. I think that a +22 offset will be way too much of an offset and I would stick to something around a +40mm offset. A +22mm offset will push your wheels outside of your wheel wells.
Old Jul 31, 2009 | 12:08 PM
archull's Avatar
This is my 18x8.5" +40mm offset wheels with a 225/40/ZR18 Nitto NT555's before I went with a wider wheel. I don't have any pics with the wider tires yet.
Old Aug 1, 2009 | 03:49 AM
thanks for the info guys. been really helpful
Old Aug 7, 2009 | 11:03 AM
scpres1's Avatar
Archull, you have one of the cleanest RSX's I've ever seen. Nice work.
Ponyboy
Apr 15, 2007 12:39 PM
torqueless
Jul 13, 2005 12:12 PM
gribbs
Jan 30, 2003 11:58 AM
