running on bad axle
Old Jul 31, 2009 | 04:19 AM
858-Luder's Avatar
Default running on bad axle
Okay, so i have been running on a bad driverside axle for about a month. Whenever i turn the wheel left just the slightest it starts clucking like crazy. The problem I dont have money to replace it right now. My question to u guys is how long will i be able to ride on a bad axle for? Im scared it might snap on me. Thanks in advance.
Old Jul 31, 2009 | 05:41 AM
PirateMcFred's Avatar
Default Re: running on bad axle
If there's clean grease and the boot's not torn you can drive on it a pretty long time. Just don't aggravate it by accelerating hard in turns. Should be ok to romp on it a little when going straight though. Replacement axles are like $99 at autozone/checker with a core. Not too expensive.
Old Jul 31, 2009 | 11:14 AM
ludeking1007's Avatar
i road on my for like 6 months and did some hard hard rideing but i just rebulit mine for like 30
Old Jul 31, 2009 | 04:04 PM
fdcusa's Avatar
Just a word of caution and a hint to just get it fixed... I've known three guys in different parts of N.C. who got pulled for improper equipment due to the buckling noise. They had to get the work done immediately and then show by demonstration that the repair work was done. My '88 (purchased new) has had them replaced twice. Each time when I started hearing the buckling, I replaced both so I wouldn't have any worries. Knock on wood -- my '88 has never left me stranded.
Old Aug 1, 2009 | 04:03 AM
rcerex's Avatar
New User
Yea, my axle is so bad that it actually Deflects the steering wheel onturns. The aligmnt shop said that I have to fix my alignant issues on my lowered car first though because it's so far out out that it's pulling the boots on my axles. I plan on getting an adjustable a-arm bolt kit .Don't forget to check that too.
Old Aug 1, 2009 | 09:36 AM
just to let you know i have that same prob and i have the a-arm kit and it dont fix the prob what helps the most is cambers and adjustable upper ball joints
Old Aug 6, 2009 | 07:12 PM
h2b eg's Avatar
bump
Old Aug 6, 2009 | 08:05 PM
Token Blk Guy's Avatar
So what I drive a Volvo
If you have a Kragen, Checkers, or what ever the other regional store is called they have axle drive shafts for 69.99 no core charge. I just picked my left one up friday. These are actually pretty easy to replace, i have done 2 on the right over the life of the 5 gen and this will be the 2nd one i have done on the left. If you have ever replaced the suspension ( lowered the lude) this is pretty easy to get to and replace yourself.
As for driving on it. i have been driving on the left one with a torn boot and most of the greese gone, for about 8 months now, ( too lazy to repair) and it hasnt started to click yet...
Old Aug 6, 2009 | 08:13 PM
TheLudeMan's Avatar
i been riding on my bad axle for about 6 months now. when i turn all i hear is clunk clunk. I need to get it fixed though
Old Aug 6, 2009 | 08:23 PM
98civdx's Avatar
Master Detailer
friend drove on his for almost 8 months before it let go.
Old Mar 1, 2013 | 04:54 PM
pssdrnx78@yahoo.com's Avatar
I have a 98 accord ex four door with bad axles i got the parts now i rode with them bad for about alittle over a year now
jordan_rael_420
Mar 19, 2009 03:04 PM
dohc_profile
May 30, 2008 09:09 AM
honda3431
Jan 20, 2007 09:00 AM
.M.
Sep 14, 2004 10:06 PM
leadfoot78
May 26, 2003 12:17 PM
