Assembly Lube Question
Old Jul 30, 2009 | 10:40 PM
hmtcrxsir's Avatar
Default Assembly Lube Question
I have a quick question, I rebuild my engine a month ago. And everything like the bearings, rod cap, is properly lube up. But my question is how long does Assembly lube will last if I was to store the engine for another month. Will the lube melt away or will no longer be good? Is there a open window period as in when I have to get the engine started?
Old Jul 31, 2009 | 06:20 AM
90Rexx's Avatar
Default Re: Assembly Lube Question
no, if you used the proper assembly lube it will be fine, but always follow manufacturer specs, so if the lube company says it has to be done by a certain time then do it lol... but in general theres no time frame
Old Jul 31, 2009 | 07:05 AM
Marauder's Avatar
Assembly lube is there to lubricate the parts before the oil starts to work. Its thick enough not to run off. Just be sure the read the label of the one you used.
One good thing to do before running the engine, is before you do it, take the spark plugs out and just crank the motor over. I will do it with the oil fill cap off, until you can see oil flowing through the engine. Then throw the plugs back in and fire her up!
Old Jul 31, 2009 | 08:03 AM
B-outAteam's Avatar
just to add on this I did a ls v with all new valve tran and new bearings and crank and eagle rods JE pis;for some one and it was in my shop for 6months?he crash he's eg right before the swap.then he got an ek and started fine 1500 2000 miles an oil change was ready to go
Nathan007
Mar 27, 2014 11:42 AM
xtreemHonda
Nov 3, 2010 12:30 PM
adeline
Jul 22, 2005 02:20 PM
Hyb
Mar 23, 2005 07:04 PM
kool168
Nov 9, 2003 06:06 PM
