Need help
I changed the d15b1 headgasket cuz it was blowing out white smoke n torqued the head bolts starting with 20lb n n then the secoond n last torque was to 49lb n now it's blowing out a lil more smoke then before..wat can be causing the smoke?!
Did you have the block and head checked for straightness?
If it's still blowing smoke, I would venture to say either the head/block are warped or it might even be just burning off the excess coolant.
I would perform a leakdown test to see whats going on with it still.
N how do u perform a leakdown test?
http://www.carcraft.com/techarticles...ter/index.html
you should probably do a compression test as well
froggie3kb
19
Oct 30, 2003 06:15 PM
