92 Accord Air Conditioning failure.
Long trip up and back, in the Central Valley of California. We stopped for gas, and when we started, the AC was a little cool, but kept getting worse. No cool air now, at all. Any suggestions?
Thanks!!
Vic
Thanks!!
Vic
belt could of snapped or there could be a leak coming from a hard line somewhere ya i would get it tested and see if it is leaking if not then it just needs to be charged back up
Thank you LT! Who do you suggest I take it to to be tested? Honda would be obscene...
This thing went pretty quickly from full-tilt-boogie to nada. (115 degrees outisde)
Thank you!!
//Vic
Thank you!!
//Vic
If you see a place that says "A/C", stop by and see what happens. You can take to a big shop and get raped for a system recharge or you can go to a descent shop and pay the normal cost, that is... if all your problem is a recharge and not a leak on the lines or anything.
if no air is comming out of the vents the blower motor is bad... very common and easy to test put the fan speed to the fastest setting mad go under the glove box and bang on it air should start to come out of the vents.
toughdame59
May 25, 2017 02:32 PM
murrellington
Aug 23, 2013 11:43 PM
