Clutch fluid over filled
Old Aug 24, 2002 | 03:08 AM
sk-itr's Avatar
Default Clutch fluid over filled
I've just noticed that my clutch fluid is fill way over the max "ridge" mark on the resevouir. Should I rush out and drain it back to the max mark ?
Old Aug 24, 2002 | 04:47 AM
IN VTEC's Avatar
Default Re: Clutch fluid over filled (sk-itr)
no
But, if you must.....use a spoon or even better....a turkey baster.
Old Aug 24, 2002 | 08:36 AM
DutchITR1689's Avatar
Clutch fluid???? WTH????
Old Aug 24, 2002 | 09:01 AM
sk-itr's Avatar
Default Re: Clutch fluid over filled (DutchITR1689)
the liquid that is displaced by pressing the clutch pedal to disengage the clutch.
Old Aug 24, 2002 | 10:55 AM
Vu's Avatar
Vu
It's the same as your brake fluid.
Old Aug 24, 2002 | 10:58 AM
uNF$@#!'s Avatar
Default Re: Clutch fluid over filled (Vu)
yes. use a pump to get it out if your really paranoid.
that extra bit should not matter.
Old Aug 24, 2002 | 12:02 PM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: Clutch fluid over filled (IN VTEC)
A SPOON should add HP shouldn't it???
later
matt
Old Aug 25, 2002 | 01:56 AM
sk-itr's Avatar
Default Re: Clutch fluid over filled (champITR)
Old Aug 25, 2002 | 06:50 AM
Oh, now I know which fluid....
Man, I think you are the only one that check that fluid level.....
Old Aug 25, 2002 | 07:18 AM
Floyd's Avatar
https://honda-tech.com/zerothread?id=262080
shortlid
Apr 14, 2007 09:20 AM
lude98SH
May 20, 2006 12:30 PM
phantom_sol
13
Sep 9, 2003 03:22 PM
Qwikrex
Apr 20, 2003 03:27 PM
KF_S2000
Jul 21, 2002 01:41 PM
