ls/vtec swap part out (MN)
Got a ls/vtec high compression motor that I'm parting out All LEGIT. I'm currently out on a business trip and wont be back until aug 9. Thats when I'll start parting it out. b18a1 block b16a2 head b16a2 tranny. Throw me an offer if your not satisfy but be reasonable. PM me and leave me a number if you'll be interested in it. I'll go down the list of people who pm me once I get back home.
B18a1 block - $500
- .25 over
- ACL
- .25 b16a2 rings
- ls rod
- machine p73
- 22t gsr/itr water pump
- vtec oil pump
- new oil pan gasket
- golden eagle kit
- ARP head bolts
- micro-polish crank
b16a2 head (1k into the head, built by kingmotorsports) - $750
- Complete valve job
- mild port intake
- Complete b16a2 intake manifold (fuel rail, injectors, TB)
- OBX TPS
- High compression supertech Dual springs/Valves
- High compression Brian Crower Retainers
- Stock b16a2 cams/ camshaft
- Resurface
- New seals
- Hondata IM gasket
- 3angle
B16a2 Transmission ( Shift like butter, no pop out) - $500
b-seres Centerforce stage3 - $100
b-series ACT lightn flywheel - $100
b16a2 shift linkage - $80
Axles (gsr driver side/ ITR intermediate and passenger side) - $120
p72 P/S with mount - $50
b-series No name Headers - $50
OBD1 vtec Distrubitor with wires - $80
Zif chip p28 ls/vtec High compression base map hondata s200 ready (by kingmotorsports) - $170
Hondata s200 with boost option and interface cord - $210
d16z6 mod engine harness - $130
p30 del sol vtec Throttle cable and mount - $50
P30 A/C Mount - $75
more too come.
B18a1 block - $500
- .25 over
- ACL
- .25 b16a2 rings
- ls rod
- machine p73
- vtec oil pump
- golden eagle kit
- ARP head bolts
- mild port intake
- OBX TPS
- Resurface
- New seals
- Hondata IM gasket
- 3angle
P30 A/C Mount - $75
more too come.
here are some quick pictures right before it was put back together and drove 5k miles. Price lowered on some parts
b16a2 tranny
ACT lighten flywheel
Centerforce stage3
b18a1 block
Do have some parts laying around too
b18b1 complete head with bare IM
PR4 rods with pistons
b18a1 oil pan (tap for Vortec supercharge but take out and sealed)
b16a2 tranny
Centerforce stage3
b18a1 block
Some other stuff I got laying around also
NEW T3 Turbo .48 ar with 4bolt downpipe $200
oil inlet line (kind of like the ls/vtec oil line) $50
96+ civic axleback tanabe medallion racing exaust (can version) $50
94+ gsr oem intake $20
94+ gsr upper mount $20
99-00 civic ex oem intake $5
92-95 civic driver side under dash harness $50
92-95 civic power option (p/m, p/l, p/w) harness $70
92-95 civic abs unit $5
99-00 p2t p/s $20
99-00 pr3 injectors w/clip $40
99-00 pr3 injectors no clip $30
92-95 cruise control unit $5
96+ honda civic dual gauge bezel $10
Hondata s200b (with boost) Blue box and interface cord only tuned for d16 turbo - $230
99-00 p2t p/s $20
evening bump, throw me some offers. Need to get rid of the car with the motor. Will let the whole car go for $2800, 93 honda civic si. Clean title Legit motor,
