Battery on front of radiator support. NHRA okay?
Old Jul 30, 2009 | 04:27 PM
vectorsolid's Avatar
Default Battery on front of radiator support. NHRA okay?
I want to hang my battery below the right front headlight on the front of the radiator support. Fitment issues aside, this is a track only car. What's the NHRA's take on that?
It would be behind the bumper cover and just above my intercooler piping and below the headlight. I have no roll cage or bars there. Just the battery hard mounted up there on the rad' support.
I know I've seen issues with fuel cells in those kinds of areas, like in front of the front tires, etc. Any thoughts?
Old Jul 30, 2009 | 04:41 PM
Garage 808 Hatch's Avatar
Default Re: Battery on front of radiator support. NHRA okay?
not sure, i know on cells, they require a 1 1/4" bar around it when not inside the steel structure of the car
Old Jul 30, 2009 | 05:12 PM
ALL IMPORT's Avatar
well u have seen pics of everyones battery box on the side in front of the tire, so why cant u put it up front & they dont use bars. needs a good base to sit in & make it look good.. deff need 1.25 pipe for a gas tank.
Old Jul 30, 2009 | 05:42 PM
jjspec's Avatar
I am pretty sure the requirement is a master cutoff if the batt is relocated and 3/8 bolts to hold it down.
Topdawgg
May 14, 2013 05:59 AM
Quickridez_3
Apr 2, 2011 08:59 AM
mikeymcm
Welding / Fabrication
Oct 5, 2010 06:18 PM
chase7687
Feb 24, 2010 06:44 PM
vietnogi
Jan 15, 2006 08:00 PM
