code 22 (vtec pressure valve) help..
Old Jul 30, 2009 | 02:21 PM
sevenfc's Avatar
Default code 22 (vtec pressure valve) help..
well i had my car running for awhile now and iv had no problems crossing vtec over till last nite...i hit vtec and after that my check engine went on and notice my vtec wouldnt crossover...so i did the procedure for check engine lights and got code 22 vtec pressure valve...how can i fix this?...do i have to change the whole silinoid or could it be wiring...i need help
Old Jul 30, 2009 | 03:36 PM
raidacaipo's Avatar
Default Re: code 22 (vtec pressure valve) help..
jdm motor? usdm motor? what ecu are you using? jdm or usdm ecu?
Old Jul 30, 2009 | 05:21 PM
JSPECSIR's Avatar
that should be the vtec oil pressure switch not the solenoid.
Old Jul 30, 2009 | 05:41 PM
Former User's Avatar
Yep. First check whether your engine oil is low.
Old Jul 30, 2009 | 06:26 PM
iamthefollower's Avatar
that's what i was about to say too lol.. if your oil level is low then it doesn't have enough pressure to have vtec kick in.
Old Jul 30, 2009 | 06:50 PM
sevenfc's Avatar
im running an lsvtec with p28 ecu with an lsv basemap...it just went on when i recently hit vtec...as for oil i just changed it and my oil level is good...
Old Jul 30, 2009 | 06:57 PM
Did you just now verify that the oil level is full? Otherwise, measure the oil pressure.
Old Jul 30, 2009 | 07:08 PM
sevenfc's Avatar
well honostly after i did change my oil it was good but i didnt really add extra for the vtec oil line or whatever and then after i did hit vtec it went on...and then i added some oil...yah kinda idiotic but thats y im asking for help...how would i measure oil pressure...do u think its wiring or my solenoid went out?
Old Jul 30, 2009 | 07:11 PM
So now you have topped off the oil, right? The next step is to clear the code from the ECU and go drive the car again. Maybe the code won't return.
Old Jul 30, 2009 | 07:15 PM
good idea
Old Jul 30, 2009 | 07:16 PM
GSaura's Avatar
Sounds like a wiring issue to me. Lacking the 30 mL of oil that fills the LSV line won't be enough to prevent vtec engagement. Trace the wiring from the solenoid to the ECU. See what you come up with. Clearing the code is at best a bandaid.
Old Jul 30, 2009 | 07:21 PM
sevenfc's Avatar
k so i went to reset the ecu, and its still the same...oil level is good..
Old Jul 30, 2009 | 07:22 PM
Depends on how low the oil may have been when VTEC engaged. If the oil level was fine, then I agree with your recommendation. If the oil level happened to be substantially low, then it would be wise to top it off, clear the code, and go for a test drive.
Edit: So I see the oil level is fine and the code is still thrown. You can test the circuit and measure the oil pressure as detailed in the service manual.
Old Jul 30, 2009 | 07:30 PM
sevenfc's Avatar
so hitting vtec could cause my circuit to get all screwed up...and with a multimeter do i test in ohms or in volts...black tip to ground and red tip to the pin correct? and another thing do i check from the obd2 plug where my vtec wires were wired in since i have the conversion harness to obd1
Old Jul 30, 2009 | 08:00 PM
sevenfc's Avatar
Old Jul 30, 2009 | 09:39 PM
raidacaipo's Avatar
How long did you drive the car for before the code 22 came on? did it just happen when you did a swap?
Old Jul 31, 2009 | 01:45 PM
sevenfc's Avatar
my motor was rebuilt but iv been driving it for almost 5 months now without that code and my vtec was working till couple days ago when it came on...so rite now iv just been driving it without vtec...which sucks haha
Old Jul 31, 2009 | 01:53 PM
raidacaipo's Avatar
could be a loose wiring.. check that first.. if you still cant figure out the problem then just bypass it.. its easy and alot of people do it including me. Mainly for jdm motors because they dont come with vtec pressure switches
Old Jul 31, 2009 | 01:55 PM
sevenfc's Avatar
how do u bypass it and whats the catch in the long run doing this...is it bad or is it normal..
Old Jul 31, 2009 | 02:06 PM
raidacaipo's Avatar
Here you go sweety.
http://www.phearable.net/tech/wiring/vtpsbypass.gif
Theres nothing wrong with running your setup like this. Ive been doing this for 4 years and no problems!
Old Jul 31, 2009 | 02:08 PM
sevenfc's Avatar
thanks will check my wires n fix it first then ill do it this way...
Old Jul 31, 2009 | 03:09 PM
nuts91civic's Avatar
Old Jul 31, 2009 | 03:11 PM
I have the same code 22. Let me know if bypassing the vtec pressure switch makes your vtec kick in. Ive had this code for a couple months now.
raidacaipo's Avatar
do it.. it will work but first thing you need to make sure is that you have proper engine oil filled up and make sure there isnt any other problems before you go and do this..
Old Aug 1, 2009 | 09:01 PM
yeah, i have a jdm obd2 b16 that i did the bypass with, it works very well.
