96 EK with GSR swap woes
Old Jul 30, 2009 | 01:48 PM
sanjiyan69's Avatar
Default 96 EK with GSR swap woes
got GSR swapped into my 96 DX sedan. it's running with a chipped p28. Checked the fuse 15 and found it was bad...got the speedo to work after replacing the fuse. However the tach doesn't work.
Any ideas on whatelse to look for?
thanks!
Wayne
Old Aug 13, 2009 | 01:10 PM
sanjiyan69's Avatar
Default Re: 96 EK with GSR swap woes
bump. still need help...
Old Aug 13, 2009 | 01:58 PM
B-outAteam's Avatar
what dizzy are u running 1 plug or two
Old Aug 13, 2009 | 08:14 PM
sanjiyan69's Avatar
obd2 dizzy.
Old Aug 13, 2009 | 08:16 PM
98civdx's Avatar
Master Detailer
2a or 2b?
Old Aug 14, 2009 | 02:54 PM
sanjiyan69's Avatar
2b.
Old Aug 14, 2009 | 02:56 PM
raidacaipo's Avatar
Originally Posted by sanjiyan69
2b.
2b in a 96 ek? hrmmm.. your using the original engine harness which is obd2a right? did you modified the wiring for the distributor?
Old Aug 14, 2009 | 07:00 PM
sanjiyan69's Avatar
The engine harness is off a 96 ex. ECU is chipped p28 with obd2a -> obd1 jumper harness. The swap is a 2000 gsr.
hopefully this helps.
Old Aug 14, 2009 | 07:58 PM
raidacaipo's Avatar
okay I see now.. have you done the conversion from obd2a ===>obd2b on the distributor yet? or did you simply try to plug and play?
Old Aug 15, 2009 | 03:24 AM
sanjiyan69's Avatar
I didn't do anything with the dizzy...was there something supposed to be done on the dizzy? please explaing. The car currently has no CELs.
thanks!
Old Aug 15, 2009 | 03:11 PM
raidacaipo's Avatar
thanks!
oh never mind.. I thought that the obd2b distributors were different from the obd2a distributors
mish__
Apr 7, 2012 07:09 PM
jksmith
Jan 19, 2009 05:25 PM
civic95hbvtec
Nov 24, 2007 08:18 PM
E_k_9 1_p_t_8
Dec 19, 2005 02:23 PM
