stering column vibrating back and forth. please help
Old Jul 30, 2009 | 01:13 PM
1nsoman1ac's Avatar
Default stering column vibrating back and forth. please help
hello all,
i have a 93 cx with a 96 ls swap in it that ive been sorta working on. by sorta i mean shes my daily as well so i cant do too much with her just yet. anyways, besised my insane idle issue, my steering wheel kinda turns back and forth when im driving. like if ur holding it, it will turn right and left about a half inch like 2 or 3 times a second. when i take a corner, it doesnt do it as much though, if at all. also, ive been starting to hear a little almost whistlinging kind of sound when i take a right turn sometimes? anybody know whats going on? a buddy of mine said it could be the lower ball joints. if so, how do i test that theory and is it something i can fix myself?
btw, alignment is correct. toe is also correct because im not eating through tires every two weeks like i used to.
Old Jul 30, 2009 | 01:25 PM
Former User's Avatar
Default Re: stering column vibrating back and forth. please help
Is the steering rack loose?
Old Jul 30, 2009 | 01:28 PM
1nsoman1ac's Avatar
lol im very new to building, or shall i say, slowly ading on parts to my civic. how do you check? oh and about the idle issue....it started idling at 1000 now and tops out at 1200 after im done. u said to reset my tps and fix the iacv? how would i do that? did u mean wait til the one i ordered comes in?
Old Jul 30, 2009 | 01:35 PM
Put the front end on stands and, at several different locations, grab the steering gearbox and try to move it with all of your might. Do you feel any free play whatsoever?
Properly calibrate the TPS (~0.45V closed, ~4.5V WOT) and do electrical troubleshooting of the IACV (does it get power; do all wires have continuity, etc.).
Old Jul 30, 2009 | 01:42 PM
j_kevin_ca's Avatar
just make sure you check all ur ball joints and tie rods.
Old Jul 30, 2009 | 01:44 PM
I misunderstood the question. I thought he meant the steering wheel was moving left to right rather than turning left to right.
Old Jul 30, 2009 | 02:21 PM
1nsoman1ac's Avatar
how would i go about doing this?
lol thank you again for helping. again another noob question: how do i calibrate the iacv? and how do i check forcontinuity? i have a multimeter...will tha work? and how do i do this?
Old Jul 30, 2009 | 06:37 PM
j_kevin_ca's Avatar
easy here is what i got from google, next time dont be afraid to do a little research. its really easy to find stuff online now.
http://www.ehow.com/how_2175979_check-ball-joints.html
as for tie rods, hold your wheel from each side, and try to shake from one side to another, if there is some clicking sound or some easy movement. means it needs to go.
KashMillien
Nov 22, 2015 07:11 PM
YoungGunnaT
Suspension & Brakes
Nov 20, 2011 11:50 PM
gsrekrevs210k
Suspension & Brakes
Jan 26, 2011 12:50 PM
Alexpbnj
Dec 6, 2010 05:05 AM
rrpenny
Oct 12, 2007 08:29 PM
